  3. Open and close ViVA sessions
  • Views 17625
CDU1
CDU1 over 10 years ago
Hello!
I am trying to open multiple Viva sessions and am using the skill command awvCreatePlotWindow()
However, when I run this a second time it only opens a new tab inside the first main window not a separate Viva window
1) How do I create a separate Viva session instead of a second tab inside the previous session?
Also the return window Id is the window Id of the Tab not the main window of the Viva Session.
I can close the tab with this window Id, but not the main Viva session.
2) How do you close the Viva Session instead of the Tab?
Thanks in advance!
- Chandra.
    That's how windows work in ViVA - they're new tabs.
    awvCloseWindow(currentWindow())
    will close the current tab.
    hiCloseWindow(hiGetCurrentWindow())
    will return the complete set. You can also use hiGetSessionWindow(hiGetCurrentWindow()) to get the session window.
  • CDU1
    Thanks, Andrew. How is this handled by ADE sessions? How do two ADE sessions open the results in two different ViVA windows?
    Best Regards,
    Chandra
    That's true. I'm not sure how that happens - if it matters to you, please contact customer support. It may require a private API and so that would need an enhancement CCR to give a public one (or it maybe that this is something that exists, and I'm unaware of).
