  3. How to use ?modifyCallback on hiCreateStringField() properly...
  • Views 17061
How to use ?modifyCallback on hiCreateStringField() properly?
Sheppy
Sheppy over 10 years ago
For a string field of a form, I want to specify a callback function which gets triggered after each keystroke. I use the function hiCreateStringField() and I specify the ?modifyCallback to trigger the function I want (it performs a rexMatchp() on a list that has all cells in a given library and puts this list as the ?choices list in an other (cyclic) form field, thus the list gets updated dynamically, making it easier to locate a cell in a library).
Somehow it doesn't work properly since I get errors.
To start, this is working fine, and the callback function works properly (just to make clear that there is no error in the code of the callback function):
  ?name       'BcipFindCellsToBrowse
  ?prompt     "Cells to browse:"
  ?value      ""
  ?defValue   ""
  ?callback   "tempProc()"
  ?editable   t
  ?enabled    t
This is the tempProc():
procedure( tempProc()
  let( ( ( temp nil ) )
    BcipGuiForm~>BcipCellsToBrowse~>value = nil
    if( equal( BcipGuiForm~>BcipFindCellsToBrowse~>value "" )
    then
      BcipGuiForm~>BcipCellsToBrowse~>choices = BcipDefineCellnameList( BcipGuiForm~>BcipLibrariesToBrowse~>value )
    else
      foreach( item BcipDefineCellnameList( BcipGuiForm~>BcipLibrariesToBrowse~>value )
        when( rexMatchp( BcipGuiForm~>BcipFindCellsToBrowse~>value item )
          temp = cons( item temp )
        ) ;;; end of when
      ) ;;; end of foreach item
      BcipGuiForm~>BcipCellsToBrowse~>choices = reverse( temp )
    ) ;;; end of if
  ) ;;; end of let
) ;;; end of procedure tempProc
So, when typing in the springfield, after it loses focus it performs tempProc() and the ?choices list of BcipCellsToBrowse gets updated accordingly.
When I do the following:
  ?value            ""
  ?defValue         ""
  ?modifyCallback   "tempProc()"
  ?editable         t
  ?enabled          t
It generates errors.
After each keystroke, the procedure tempProc() gets executed (I know that since the ?choices list gets updated correctly) but the following error is reported in the CIW:
*Error* eval: not a function - 'BcipFindCellsToBrowse
*Error* car: Can't take car of atom - ERROR
I get the same error if I replace "tempProc()" with "printf(\"Help\")".
When I look at the documentation, the explanation for ?callback differs significantly from the ?modifyCallback explanation.
The ?modifyCallback passes three values to the callback function (s_filename, t_lastTextValue and g_sourceOfChange) and it expects to get back either t, nil or a value. This is where it is breaking in my code, I suppose. I have tried several things (like returning a "t" at the end of tempProc()) but none of them worked.
So I would like to know:
  • the ?modifyCallback passes three values, how do I access them (for an other form I really want to know what the g_sourceOfChange is)
  • How do I return something to satisfy the ?modifyCallback of the field?
  • And what should I return (simply "t")?
  • Is there a smarter method for what I want (something already build into Cadence/SKILL)?
Any help is highly appreciated since I hate to distribute code that works but generates errors.
With kind regards,
Sjoerd
ps:
This is what BcipDefineCellnameList() does:
procedure( BcipDefineCellnameList( refLib "l" )
  let( ( ( lib nil )
    ( libDbId nil )
    ( cell nil )
    ( cellNameList nil ) )
    foreach( lib refLib
      libDbId = ddGetObj( lib )
      foreach( cell libDbId~>cells
        if( member( cell~>name cellNameList )
        then
          cellNameList = cellNameList
        else
          cellNameList = append( cellNameList list( cell~>name ) )
        ) ;;; end if
      ) ;;; end foreach cell
    ) ;;; end foreach lib
    cellNameList = ( sort cellNameList nil )
  ) ;;; end let
) ;;; end procedure BcipDefineCellnameList
refLib is a list of strings, each string is the name of a library.
    Hi Sjoerd,
    I didn't try to get your code working in an example, but I can see what's wrong. The ?modifyCallback is expecting just the name of the function, not the function call itself. It will then automatically add three arguments to it before it's called - so that would be as described in the documentation:
    A modify callback function of string type is passed the following arguments:
    s_fieldName t_latestTextValue g_sourceOfChange
    where s_fieldName is the symbol of the field in which the change was made, t_latestTextValue is the latest text value of the field, and g_sourceOfChange is t or nil where t indicates that the change was made programmatically (by changing the value of the field) and nil indicates that the change was made by a user action.
    So please specified ?modifyCallback "tempProc" and then define your tempProc function to accept three arguments. The error you're getting is because it calls:
    tempProc()('BcipFindCellsToBrowse "whatever" nil)
    It therefore thinks that BcipFindCellsToBrowse is a function name, which it isn't, and hence it fails.
    With just "tempProc" specified, it would call:
    tempProc('BcipFindCellsToBrowse "whatever" nil)
    which is the correct function call. Of course "whatever" in the above statements is just a placeholder for whatever you actually typed.
  • Sheppy
    Fantastic, it works! Thanks for your quick reply.
    With kind regards,
    Sjoerd
