  3. Add a button into transCdlOutForm
  • Views 15378
nidon2003
nidon2003 over 10 years ago
Hi everyone,
I just try to add a file browse button for cdlOIncFile ("include file") in transCdlOutForm when i ues it, the code as follow:
cxtPath=prependInstallPath("/etc/context/transUI.cxt")
unless(boundp('transCdlOutForm) loadContext(cxtPath)
testCdlIncFileBrowse=hiCreateFormButton(
                                                         ?name 'testCdlIncFileBrowse
                                                         ?buttonText "...."
                                                         ?callback "ddsFileBrowseCB(transCdlOutForm 'cdlOIncFile)" )
hiAddField(transCdlOutForm list(testCdlIncFileBrowse 630:459 35:35) )
When i load it,  the CIW shows the warning: hiAddField: invalid filed description
But i try to add this button into a form which i created, it's no problem.
So i don't know where the issue is~~~~
Please help me , thank you very much!
  • skillUser
    skillUser over 10 years ago
    I tried your code in IC617 (ISR3) and it worked (the button is quite a way off the form, I had to scroll to see it). Perhaps the version you are using has a bearing on this issue, which version are you using?
    Lawrence.
  • skillUser
    By the way, the version I tried already has a Browse button for the Include file field, so it wouldn't be needed anyway. You must be using a much older version?
  • nidon2003
    Thany you, Lawrence. And i will try to update my version.Thank u!
