  3. Descending into a group from figure coordinates in layo...
  • Subscribers 150
  • Views 17873
Descending into a group from figure coordinates in layout
frankliu
frankliu over 10 years ago
I have groups (figure groups) within groups ..., i.e. nested groups.
From the toplevel of the hierarchy, I would like to descend to the geometry under point.
Given that I cannot select the geometry at toplevel because it is deeply nested in other groups, what is a good way of getting to it.
Yes, it is possible that the geometry at point may be overlapping other geometry in the same layer, in which case I would like to have all the possible choices under point.
Thanks in advance.
  • psill000
    psill000 over 10 years ago
    If you are just editing groups interactively, have you tried turning on/off the groups transparency?
    Enable the Options toolbar
    Toggle the Transparency Group
    Paul
    Just working something, you have to specific on shape you want to edit; otherwise, it will pick the first shape it finds. I have not test it with hierarchy. I tested it at cell level.
    procedure(editInPlaceFigGrp()
    let(    (shpDb grpDb
        (cv geGetWindowCellView())
        (pt enterPoint()))
    shpDb = car(leSearchHierarchy(cv list(pt pt) 32 "any shape" nil))
    foreach(grp dbFigGroupQuery(cv list(pt pt) 0 32)
        if(member(shpDb grp~>figs) grpDb = grp))
    if(grpDb leSetEditFigGroup(grpDb))
    ); end of let
    ); end of ausPSXeditInPlaceFigGrp
  • psill000
    Saw a problem with the script, updated.
    Its some to build on.
    I have not added for other variables in the group, anything other than a shape.
    procedure(ausPSXeditInPlaceFigGrp()
    let(    (shpDb grpDb
        (pt enterPoint()))
    foreach(shp leSearchHierarchy(cv list(pt pt) 32 "any shape" nil)
        if(leIsLayerVisible(shp~>lpp) shpDb = shp))
    ); end of let
  • frankliu
    Hi Paul, thanks for code snippet, I will give it a try. -f
  • frankliu
    Hi Paul
    I noticed that
    grp~>figs
    returns a list of lists for me, I used (car grp~>figs) for now, and it does the job, but I was wondering if I am missing something, what does each list in figs represent?
    -f
  • psill000
    grp~>figs returns all the objects in the group; shapes, vias, groups, instances.
    With the car(grp~>figs) your are returning the first object in the group. I used the is visible as a filter for the objects in the group.
    Paul
