  3. Accessing dynamic form fields
  • Views 5747
FormerMember
FormerMember over 10 years ago
Hello everyone,
I'm building a form, that is supposed to read something and then depending on that number, it outputs a form with fields with the same number. For example:
for(i 0 length(namesList)-1
namesHandle=hiCreateCyclicField(
?name makeSymbol(strcat("sym" sprintf(nil "%L" i)))
?choices '("" "a" "b")
?prompt " "
?value ""
);hiCreateCyclicField
);for
The code, afterwards, goes on with the same manner to create a 2D form with number of fields.
The form is beautiful and everything is perfect, except for one thing. I want at the end to let the user enter his data and then save his inputs into a file.
I can create the file and save whatever I want to it but for some reason I can not access the values of the form fields.
If I write in CIW this command: myform->sym2->value I get the current value of that field with no problem. But since I don't know the number that is attached to sym because this number is totally generic, it always brings back nil if I replace sym2 with something else like makeSymbol() or concat("sym" i) where i is a for loop counter
foreach(name namesList
fprintf(filePort "%s" name)
fprintf(filePort "%s\n" myform->sym0->value)
What I need, at the end, is to be able to loop through this field's names to retrieve every value attached to it.
Any help is appreciated, thanks
Sherif
    Hi Sherif,
    count=0
      fprintf(filePort "%s\n" get(myform concat('sum count++))->value)
    That should do it.
  • FormerMember
    Man you're awesome!! You just saved my day!! Thanks A LOT!
