  3. Custom skill code to find point-point Resistance in lay...
  • Subscribers 148
  • Views 17343
Custom skill code to find point-point Resistance in layout
ssram
ssram over 10 years ago
Could anyone share the skill code to find point-point Resistance in layout? I hardly have an idea how this is gonna work, but i'm sure this might need to use layout extraction once you trigger the find R in the code. I'm not sure there is another way to actually find this. Any help?
Sooraj
    Hi Sooraj,
    Do you have access to Virtuoso Electrically Aware Design? (EAD). This provides this functionality. Writing this yourself in SKILL is not exactly a simple task...
    EAD has the benefit of being able to work on partial layouts, compared with using a signoff extractor like Quantus QRC.
  • ssram
    Unfortunately, i do not have EAD license.Thanks Andrew.
  • ssram
    But i was thinking that i could hard code the Sheet Resistance in the script and i do not have to do an extraction to get the point-point R. What i'm thinking is not the best way though like the extracted method, but its going to be faster and with a tolerance of 5-10% which i think i can live with. But again, i'm not sure how i'm gonna trace the whole net, i've to use the markNet kind of function to get this done! I'm Confused...
    This is one of those things that soon descends into something very complicated - as soon as you have parallel paths between two points, it gets messy. Even tracing the shortest path gets complicated. I don't have any SKILL to do this - and you'd almost certainly be better off looking at EAD rather than trying to write your own.
