  3. Getting list of objects in a database
  • Replies 9
  • Views 24381
archive over 18 years ago
Say I have this code which opens a cell view and assigns the database id to test.
test = dbOpenCellViewByType("library" "cellname" "view")
Is there a way to get a list of all the available objects in this database?
Right now, I loop through each object and print its name.
foreach(i test~>instances
            println(i~>cellName)
For debugging I would like to be able to print a tree of the heirachy of the database. Is this possible?
Does the dbFindProp() function have something to do with this?
Originally posted in cdnusers.org by ahamlett
    Design->Hierarchy->Tree has already got all the info apart from top level shapes which can be accessed using:
    test~>shapes
    Raj
    Originally posted in cdnusers.org by rairaj
    Sourcelink has some examples:
    http://sourcelink.cadence.com/docs/files/Application_Notes/2002prev/Framework_Application_Notes/Database_Traversal.html
    -Derek
    Originally posted in cdnusers.org by dmay
    Posted By rairaj on 12/19/2007 10:27 AM
    test~>shapes
    Raj
    That gives me the hierarchy of cells, but I want objects such as test~>libName.
    I need a list of all the data objects available inside the test database such as libName, cellName, layerName etc.
    Try the attached code. I think you'll find it useful...
    Originally posted in cdnusers.org by adbeckett
    dataBrowser.il
    test~>? gives you all the attributes
    test~>?? gives all the attributes and their values
    But remember that some of the values could be db ID's so a further foreach will be required.
    dataBrowser.il will give you a graphic represenation of database so you can drill down by just a click.
    Posted By adbeckett on 12/19/2007 10:36 AM
    Thank you!
    Posted By rairaj on 12/19/2007 10:40 AM
    Thank you too!
    This was exactly what I have been looking for :)
    I didn't even have to load dataBrowser.il because TI had already loaded it into Cadence!
    I can learn a lot from that source code. Thanks!
  • wferguss
    wferguss over 17 years ago
    Can someone please upload dataBrowser.il again?
    It seems to be missing from the forums.
    Walter
  • ahamlett
    ahamlett over 17 years ago
     http://uan.no-ip.com:8080/~ahamlett/uploaded/dataBrowser.il
