  3. Using lxGenFromSource command, how to use layout_example...
  • Subscribers 148
  • Views 15179
Using lxGenFromSource command, how to use layout_example view from tech library
San
San over 10 years ago
Hi all,
I am using lxGenFromSource command and generating layout of a pcell.
But in my tech library , cell do not have "layout" view , instead it have "layout_example" view.
How can I tell my code to use "layout_example" view to generate layout using the lxGenFromSource command.
Please guide.
Sanket
    Sanket,
    The simplest approach is to use:
    envSetVal("layoutXL" "stopList" 'string "layout_example layout compacted symbolic")
    before VLS XL has been started. This will set the default physical stop list for the phys config.
    Alternatively, you can use:
    cph=cphGetLayoutXLConfig(geGetEditCellView())
    cphSetStopList(csh "layout_example layout compacted symbolic")
    after you've started VLS XL.
  • San
    Great. Thanks a lot Andrew. I appreciate it.
    Sanket
