  3. force renumbering of instances
  • Views 17445
NoelCFC
NoelCFC over 10 years ago
I like to know if it is possible (and if it IS possible, how) to force the renumbering of all instance of a given schematic, even on instances where the number has been changed manually by the user.
thanks in advance.
best regards,
  • skillUser
    skillUser over 10 years ago
    Hi Noel, In the Schematic menu choose Edit -> Renumber Instances, and select "Sequence instances by" to something other than "filling the voids" (e.g. "X+Y+"). There is an API command also (schRenumberInstances()) if you want to run it through SKILL rather than the menu and form approach. Best regards, Lawrence.
  • NoelCFC
    hi, Lawrence.
    thanks for the promptly reply.
    I've used the Edit -> Renumber Instances before but what I was looking for is a way to renumber a transistor that has been numbered as Mdiff1, for example. In these cases, the Edit -> Renumber Instances doesn't work.
    Perhaps you can adapt this article to do what you want?
  • NoelCFC
    thanks, Andrew.
    I'll look at the solution.
