  3. Using OCEAN to plot user defined waveforms across Design...
  • Views 1549
Using OCEAN to plot user defined waveforms across Design-Points/Corners
Paul Scofield
Paul Scofield over 10 years ago
Hello
I'm using ADE-XL to run block level simulations across Design Points/Corners against specification limits. I use an OCEAN script to setup outputs. I use a SKILL script to auto generate waveforms in a format useful for documentation into various sub-windows including titles and labels. This fine for a single run but generates multiple windows when run over Design Points/Corners.
How can I code a script to place all waveforms, of a specific point of interest, into the same sub-window. It is also necessary to add a suffix to the waveform name which takes in the Design Point or Corner run.
Regards
Paul
    Paul,
    Without seeing what you're doing that is causing the problem, it's hard to offer advice without giving a complete worked example (which might miss the mark completely). So I suggest you contact customer support so you can share the details of what you're doing.
    Kind Regards,
