  3. Write to the ADE L output window
  • Views 15644
rbahr
rbahr over 10 years ago
Hi there,
I'm moderately new to the SKILL API, but I didn't see anything immediately that allows writing to the ADE L outputs window, the area to the bottom right of the Design Variables and Analyses. I think I saw a related function to ADE XL (axlAddOutputs, may not be the right one though), but couldn't find one related to ADE L.
Ryan
  • skillUser
    skillUser over 10 years ago
    Hi Ryan, look at the ocnPrint() function, this can output results to a file, either scalar values, or sampled waveforms (using the ?from and ?to arguments). The 'getData' function is the generic access function to some results, but you can also use functions like i() and v() . Look at the calculator expressions for the outputs section. You can use the "Session -> Save Ocean Script" to automate this and then tweak the resultant file. Hope this helps! Lawrence.
    If you're asking how to add an output to the ADE L outputs pane using SKILL, then there isn't a public SKILL API to do that.
  • rbahr
    That is what I thought. Thank you Andrew for again answering all of my questions.
