  3. how can i compare lines after match pattern in skill
  • Subscribers 150
  • Views 15420
acom
acom over 10 years ago
Hello ,
I have 1 file which contains 2 parts.One part is the schematic hierachy  tree.Another part is the layout hierachy tree.(looks like below)
Based on this file, how can i compare the schematic hierachy tree VS layout hierachy tree by using skill?
That is, eg . In schematic ,  "BlockA/ Lib2 Cell2 schematic";In layout, it is "BlockA/ Lib2 Cell2_2" layout.How can i check this kind of errors by using the below file?
schematic_layout_tree file:
#CellView BlockA schematic#
subcell: 3 sub cells
    Lib1 Cell1 schematic
    Lib3 Cell3 schematic
#CellView BlockB schematic#
subcell: 2 sub cells
    LibB1 CellB1 schematic
    LibB2 CellB2 schematic
#CellView BlockA layout#
    Lib1 Cell1 layout
    Lib2 Cell2_2 layout
    Lib3 Cell3 layout
#CellView BlockB layout#
    LibB1 CellB1 layout
    LibB2 CellB2 layout
  • fatcat1206
    fatcat1206 over 10 years ago
    Hi acom
    I take a look on the hierarchy tree of schematic/layout.
    The tricky part is that the hierarchical information is shown by the order and indent.
    What I am afraid, is that if you want to make a decent comparison, you need to recreate the hierarchy of schematic and layout while you reading the file.
    By nature of reading the file, you would know the order of the line, and also you can count the how much space is inside the indent.
    So with this information, you can recreate the hierarchical information.
    You can either save them into a disembody proper list, or a structure defined by your self.
    Then you can do the comparison based on these two lists/structures.
    Best Regards
    Yi
  • acom
    Hello Yi,
    Thanks for your reply here.I shared the same idea with you :)
    But the difficult part for me is that i don't have a good way to transfer the file into 2 lists/structures.
    There are tens of thounds of lines like this in the file.I have know idea how to do it more efficient.
    Ada
  • fatcat1206
    Hi Ada
    You can always try with a short list.
    most important thing is to defined your structure format.
    One thing cross my mind, the cell may come from different lib.
    So, unfortunately, you may need to save both lib and cell info for every line you have read.
    Of course, at the some time build up the hierarchy structure.
    Best Regards
    Yi
