  3. encryption question
  • Subscribers 148
  • Views 20079
encryption question
mctang
mctang over 10 years ago
Hi  All,
1. I type the following command in CIW
     encrypt( "abc.il" , "abc_enc.il")
    Could anther user convert abc_enc.il to ASCII file ?
2.  I type the following command in CIW
     encrypt( "abc.il" , "abc_enc.il", "pass" )
    Could anther user convert abc_enc.il to ASCII skill file if the user has the password ?
ManChak
  • skillUser
    skillUser over 10 years ago
    Hi ManChak,
    1) potentially, simply loading the abc_enc.il file will decrypt it in virtual memory, with a SKILL debug key it could be pretty printed and/or written out. By default the function is read-protected.  Also you can set the function to be read and write protected by putting it in a context instead; this is your safest bet.
    2) essentially the same as 1) - you need to provide the password to read the file, I believe, and then you're in the same position as in 1).
    Best regards,
    Lawrence.
  • mctang
    Hi Lawrence,
    1. Thank you for your info. Could you point me to the document to generate context file ? Foundry pdk uses context file, but I do not know how to generate it.
    2. Regarding item 2, does the user need password to run my skill code ? Or the password is just used to convert abc_enc.il into ASCII file.
    ManChak
  • skillUser
    Hi ManChak,
    1. Look for "setContext" and "saveContext" in the documentation. I'm not going to search for you, you can type "context" in the Search box in a design window, or even in the cdnshelp tool, or perhaps in the Cadence Online Support site. The docs include a short example that explains the basic flow:
    ;; to create a context named "current" and saved as "myContext.cxt" (I'd be more consistent with the name):
    setContext( "current")
    load("mySkillCode.il")
    defInitProc("current" 'myInit) ;; this is entirely optional
    saveContext("myContext.cxt")
    2. The password is needed to read/load the code but after that it can be run without needing a password. I personally wouldn't bother with this method, I think I'd use a context file.
    Best regards,
    Lawrence.
    To answer the original questions, a non-password encrypted file is pretty easy to see the source; I won't go into the details here - but you should simply class this as a minor deterrent against somebody being able to mess with the code, rather than any protection.
    If you provide a password when encrypting the file, then the method typically used to see the source no longer works. You do need to provide the password when loading the file (second argument to the load() function), and as with all encryption, the code is read protected (you cannot use the pp() function). I wouldn't say the encryption is "strong" but I'm not sure I'm aware of anyone who has gone to the lengths to figure out how to crack the encryption.
    As Lawrence said, generally a context file offers the best protection as you're essentially providing the compiled virtual machine code. Provided you remember to set writeProtect before you create the context, the code won't be pp-able.
    I tend to use password-encryption for small fixes that need protecting, and context files for bigger chunks of code.
    Kind Regards,
  • mctang
    Hi Andrew and Lawrence,
    ManChak
