  3. If condition failure
  • Views 19530
LaksNanu
LaksNanu over 10 years ago
I am new to skill,
I am checking if any of the windows are opened, if windows are available, then check if particular (lib,cell,view) are opened,
if the layout is not already opened then print the statement. (i will substitute print statement to deopencellview later).
I am unable to find the problem with the below code. As it is not working properly, when i open cell view, it prints absent statement.
procedure( lpFgOpenDB()
   let( (openWin svw)
      openWin=cdr(hiGetWindowList())
      foreach(svw (openWin~>cellView)
         if( !(((svw~>libName) == "lp_amr") && ((svw~>cellName) == "apple") && ((svw~>viewName) == "layout"))
          then
           printf( "apple is absent\n" )
         else if( !(((svw~>libName) == "lp_amr") && ((svw~>cellName) == "orange") && ((svw~>viewName) == "layout"))
          then
           printf( "orange is absent\n" )
         );else if
         );if
      );foreach
   );lef
);proc
An alternative to the above code is also helpful
Thanks & Regards,
Lakshmiprashanth
((svw~>libName) == "lp_amr" && (svw~>cellName) == "fromlayout" && (svw~>viewName) == "layout")
    Your code will always say either "apple is absent" or "orange is absent" because for each window, it will check first that it is not "apple" - if so, it will print that, otherwise if it's not "orange" it will print that. Put another way, if the window contained "apple", it would tell you that orange was absent. If it contained "orange", it would tell you that apple is absent. That's not really a specific SKILL issue, it's a programming logic issue.
    I suspect what  you really want to do is find out for a particular lib/cell/view whether it's in a window already. You could do:
    procedure(CCFfindExistingWindow(libName cellName viewName)
      let((svw)
        car(exists(win hiGetWindowList()
           svw=win~>cellView
           svw~>libName==libName && svw~>cellName==cellName svw~>viewName==viewName
    If you then do CCFfindExistingWindow("lp_amr" "apple" "layout") it would return the window id of the window containing it, or nil if not found.
    Alternatively, you could use these built-in functions instead:
      let((cv)
        cv=dbFindOpenCellView(ddGetObj(libName) cellName viewName)
        cv && geGetEditCellViewWindow(cv)
    That's probably a bit more direct.
  • skillUser
    skillUser over 10 years ago
    Hi Laksmiprahanth,
    I think that the issue is that perhaps you are expecting the "!" to cover combined "&&" statements, however it has a higher precedence than the other operators and so only applies to the first item of the statement. You can rewrite the statement using the function rather than the operator, it should correct the problem and may offer more clarity:
    if( null(and((svw~>libName =="lp_amr")  (svw~>cellName == "apple") (svw~>viewName == "layout"))) then ...
    Hope this helps!
    Best regards,
    Lawrence.
    Hi Lawrence,
    Our responses crossed. However, I don't think you're right. The three && conditions are surrounded by parentheses, and so the ! is doing the not of all of them, not just the first. Put another way, it's the same as your code.
    To show this, I used sstatus(printinfix nil) and pp'd the original code:
    (if
      (null
        (and
          (equal
            (getSGq svw libName) "lp_amr"
          (equal
            (getSGq svw cellName) "apple"
          (equal
            (getSGq svw viewName) "layout"
     ) then
     (printf "apple is absent\n")
  • skillUser
    yes, you are right, I missed that. Too many parentheses ! I'm glad that you provided the correct answer!
    Cheers,
    Lawrence.
  • LaksNanu
    Hi Andrew & Lawrence,
    Thanks for helping me to understand the mistakes,
    And moreover the code given by you is working .
    This is what I needed.
    Lakshmiprashanth
