  3. deRegUserTrigger warning message
  • Subscribers 148
  • Views 15969
mctang
mctang over 10 years ago
Hi All,
I created a  skill code which uses deRegUserTriggers. I get the following warning message when I open same layout. Is there an solution for this issue ?
*WARNING* __deMakeBannerMenus ("maskLayoutXL"), duplicate menu(s) removed
deRegUserTriggers("maskLayout" nil 'trLeBannerTrigger nil)
procedure(trLeBannerTrigger(args)
list(bkLePulldownWindow())
deRegUserTriggers("maskLayoutXL" nil 'trLeBannerTrigger nil)
deRegUserTriggers("maskLayoutGXL" nil 'trLeBannerTrigger nil)
ManChak
    ManChak,
    I don't see this problem with your code - so I can only assume that you must be adding (via some other mechanism) the menu more than once. Perhaps you have registered multiple different menu triggers each adding the same menu?
    I just defined:
    procedure(bkLePulldownWindow()
      hiCreatePulldownMenu('bkLePull "bk menu" list(hiCreateMenuItem(?name 'item1 ?itemText "ITEM 1" ?callback "println(12345)")))
    and then loaded your code. It worked fine.
  • mctang
    1. nk you. You are correct. I have registered multiple different menu triggers each adding the same menu. If I run the following command a few times in the same layout window, will I get the following error message  (duplicate menu removed) ? The following warning appears when I invoke SKILL code from pulldown menu.
    deRegUserTriggers("maskLayoutXL" nil 'trLeBannerTrigger nil) procedure(trLeBannerTrigger(args) list(bkLePulldownWindow()))
    2. The SKILL contains he function which performs poly bias and "deRegUserTriggers("maskLayoutXL" nil 'trLeBannerTrigger nil) procedure(trLeBannerTrigger(args) list(bkLePulldownWindow()))". Thus, deRegUserTriggers command is called when I try to bias poly. Is it correct to include deRegUserTriggers in the Skill code which performs poly bias and createspulldown menu ?
    ManChak
    ManChak,
    I don't know which version you're using (this piece of generally important information was not mentioned by you), but as far as I know, repeatedly registering the same trigger function does not cause it to be duplicated - it ignores the duplicate. It would give a warning telling you this - such as:
    *WARNING* (DEBASE-102202): User menu trigger 'trLeBannerTrigger' is already registered for viewType maskLayoutXL.
    I have no idea what  your second question even means. It is so devoid of context that it's impossible to answer.
  • mctang
    Thank you for your info.
    My Virtuoso version is ICADV12.1-64b.
    ManChak
