  3. How to automatically store technology version on instance...
  • Replies 17
  • Subscribers 150
  • Views 24052
How to automatically store technology version on instance in schematics and layout?
Sheppy
Sheppy over 10 years ago
I'd like to store the version number of the PDK on an instance when this instance is instantiated in schematic or layout. I need this in order to be able to check with which version of the PDK a particular design has been made. Later, I will create a script that hierarchically checks all instances of a given design, and reports the used versions. This will then be a script run at tape-out to ensure all devices are generated with the correct (latest) PDK version.
It could be done by adding a parameter with the version number as value to the CDF, like this:
cdfCreateParam( cdfId
        ?name           "PDK_version"
        ?prompt         "PDK Version"
        ?defValue       "x.y.z"
        ?type           "string"
        ?display        "t"
        ?editable       "nil"
        ?storeDefault   "yes"
However, if the PDK gets updated, the version number will be increased, which would mean, with this implementation, that the CDF of all cells in the library have to be updated to the new version. Of course, this could be automated, but i would like to use a different approach.
The version of the PDK which is loaded in Virtuoso is stored in an environment variable called TECH_VERSION. It can be retrieved by doing:
getShellEnvVar( "TECH_VERSION" )
What I would like to happen is that when the instance is instantiated, the value of TECH_VERSION is automatically stored in the CDF parameter PDK_version. Something like this doesn't work:
        ?name           "PDK_version"
        ?defValue       "getShellEnvVar( \"TECH_VERSION\" )"
        ?type           "string"
        ?display        "t"
        ?editable       "nil"
        ?storeDefault   "yes"
This would simply put the text "getShellEnvVar( "TECH_VERSION" )" as value in the "PDK_version" field.
An other solution could be by putting some code in a call-back procedure that puts the version number in the parameter value. However, this only works when this call-back procedure is triggered. If a default device is instantiated, with no modifications to its parameters, the call-back will not be triggered, thus the version number will not be set.
So, I think this has to be a post-instantiation trigger. And I don't know how to do that properly. Any help is highly appreciated.
If an other solution is possible, I would surely like to know that as well.
Thanks in advance.
With kind regards,
Sjoerd
  • fatcat1206
    fatcat1206 over 10 years ago
    Hi Sjoerd
    can you try this:
           ?name           "PDK_version"
           ?defValue       getShellEnvVar("TECH_VERSION" )
           ?type           "string"
           ?display        "t"
           ?editable       "nil"
           ?storeDefault   "yes"
    As you put the getShellEvnVar() functions into the quotation marks, then it has been treated as string.
    Best Regards
    Yi
  • Sheppy
    Hi Yi,
    Thank you for your reply.
    Unfortunately, this solution is not working for me. This solution will hard-code the PDK version in the CDF, it will not make it "dynamic". When the file with the CDF parameters is loaded, the line you proposed (see quote below), will simply be evaluated and results in a hard-coded version number in the "PDK_version" parameter.
    This is not what I want to achieve.
    I want that when the cell is instantiated, it will then store the value of "TECH_VERSION" in the parameter "PDK_version".
    Just imagine the following:
    The current version of the PDK is 5.5.5 (= TECH_VERSION), and I have a cell called NMOS. I make a change to the PDK which is totally unrelated to the cell NMOS (maybe a start-up sequence change, or something completely different). The "TECH_VERSION" will be incremented to 5.5.6. If I do what you propose, and I instantiate the NMOS in a cell using the 5.5.6 version, it will still store 5.5.5 as the value for "PDK_version". In order to have that fixed, I have to re-load the CDF pararmeters SKILL file (the one with the cdfCreateParam statements in it) to set it to the correct version. This extra step, which has to be performed every time a new PDK is compiled, is what I don't want to do.
    What I want: regardless of what changes in the PDK, once a cell (i.e. NMOS) is instantiated, it stores the value of the "TECH_VERSION" in the "PDK_version" parameter. So even if the CDF parameters of the NMOS are not reloaded, it will still store the version of the PDK the cell was instantiated. Since it has to work on default devices too (devices for which none of the parameters change from the default thus not triggering the call-back procedure) I think it has to be a post-instantiation triggered call-back.
    With kind regards,
    Sjoerd
  • fatcat1206
    Hi Sjoerd
    You are right, with what I propose there, the PDK_version is indeed hard copied.
    Sorry that I misunderstood your example, I used think you want to use getShellEnvVar() for the default value.
    I am thinking the same way as you did. A post trigger call back is needed after the instantiation.
    Is that possible to add an extra call back when "Add Instance" form is closed?
    Then we may update the PDK version there.
    There are might be some issues when the instance is not added via calling the "Add Instance" form.
    We may deal it later.
    Best Regards
    Yi
  • skillUser
    skillUser over 10 years ago
    Hi Sjoerd,
    Look in the documentation for "formInitProc" - this is a procedure that is automatically called when the Create Instance or Edit Object Properties form is displayed - you could use this to set/update the PDK_Version CDF property. You could use a 'doneProc' too, but I think I would look at the formInitProc first.
    Hopefully this will help you.
    Best regards,
    Lawrence.
  • Sheppy
    Hi Lawrence,
    Thanks for your reply, and pointing me in the right direction. Both of the options llok very promissing after reading a bit. I think the doneProc would work best for me.
    I'm going to do some tests with both to see what happens if I open a cell with instances of a previous PDK, that do not have the "PDK_version" parameter, and then open the "Edit Parameters Form", and see how that works out. Code I put in the procedure for "doneProc" or "formInitProc" should check and handle accordingly for a situation like that.
    I'll update this post with my solution.
    With kind regards,
    Sjoerd
  • Sheppy
    Hi Yi, after I re-read my initial post I see where your confusion comes from. I should have included the example in my original post. Lawrence (see below your post) came with what I think will be the solution. I am testing it right now and will update this post accordingly. Thanks again. With kind regards, Sjoerd
  • fatcat1206
    Hi Sjoerd
    Wish you success for the solution, and really looking for it.
    It's a coincident that one of my colleagues asked for a procedure which can ban certain instance being instantiated today.
    I am thinking, I may reuse your framework.
    Instead of putting the PDK version into cdf parameters, I can do a check and somehow break the procedure of instantiating or delete such instance after instantiating.
    Best Regards
    Yi
  • Sheppy
    Hi Lawrence,
    Using both CDF options I can get the version number into the parameter. However, there is one huge drawback by using this: if I select an  instance which is created using an older version (that may or may not have the parameter set) upon looking at its properties (hitting the "q" key) and changing one parameter, the version number gets updated. This is something I don't want to happen. If it is not set, it should keep it untouched.
    This is what I added to the CDF parameter file:
            ?name           "PDKVersion"
            ?prompt         "Created with PDK Version"
            ?defValue       ""
            ?type           "string"
            ?display        "t"
            ?editable       "nil"
            ?callback       "ZP250hvmosCB('PDKVersion)"
            ?storeDefault  "no"
    cdfId->doneProc                = "spdkSetPDKVersion"
    This is the code of the "doneProc" procedure:
    procedure( spdkSetPDKVersion( cellId )
        let( (    ( pdkVersion "" )
            ( cdfgData nil ) )
            pdkVersion = getShellEnvVar( "TECH_VERSION" )
            cdfgData = cdfGetInstCDF( cellId )
            ;;; Only if not set yet, set the PDK version...
            when( equal( cdfgData->PDKVersion->value "" )
                cdfgData->PDKVersion->value = pdkVersion
            ) ;;; end of when
        ) ;;; end of let
    ) ;;; end of procedure spdkSetPDKVersion
    What I think I need is a method to know how the procedure was triggered. I mean: was it triggered after instantiating a new device, or after any of the parameters were changed from an "Edit Object Properties Form". If I am able to determine this, it is easy to define whether or not the parameter must be updated.
    Do you know a method of doing that?
    With kind regards,
    Sjoerd
  • fatcat1206
    Hi Sjoerd
    I am thinking that the triggering of the procedure is not through initProc or donePorc of the CDF parameter.
    We may use triggering functions calls via event.
    The corresponding API is "ddRegTrigger()", and considering your case, the trigger name "PostCreateObj" might be an good option.
    You may check the "cadence design framework II skill functions reference" for the details.
    Best Regards
    Yi
  • fatcat1206
    Hi Sjoerd
    I try the method I mentioned above.
    It does not work.
    The reason might be that when using the GUI to instantiate an instance, "ddCreateObj()" is not used.
    Best Regards
    Yi
