  3. Accessing and modifying toolbar items in IC616
  • Subscribers 148
  • Views 16284
RK56
RK56 over 10 years ago
Problem 1:
I have followed the Solution Article 11478824  to create a toolbar in layout window. Now I need to access the items of toolbar and I have used hiGetToolbarObjName function to do that. But I'm looking for a generic way to access the items something like this
csToolbarGetElement(element) ;;;;;where element is a string which points to one of the toolbar item
csToolbarGetElement(element)~>value ;;;;;should return the value of the element
Problem 2:
I have created few subActions and a comboFiled to list the subActions. Whenever I select any subAction, I need to change the icon of the comboFiled. For example, I'm looking for a implementation similar to Options Toolbar -> Edit Snap Mode in layout window. Whenever I change the snap mode, the icon of the combo file changes notifying the user the present mode.
Please free to ask question in case I have not explained my need clearly.
Ramakrishnan
    Andrew Beckett over 10 years ago +1
    If you have the toolbar object, you can find the names of the items, and then the attributes of all items. For example, for a schematic: toolbars=hiGetWindowToolbars(hiGetSessionWindow(hiGetCurrentWindow…
    toolbars=hiGetWindowToolbars(hiGetSessionWindow(hiGetCurrentWindow()))
    fileTB=car(exists(tb toolbars hiGetToolbarObjName(tb)=="File"))
    fileTB->items
    (schFileToolbarNew schFileToolbarOpen schFileToolbarCheckAndSave schFileToolbarSave)
    Then you can look at an individual item:
    fileTB->schFileToolbarNew->??
    (hiNameSym schFileToolbarNew hiType action hiCallback
        "schHiNewCellView()" hiIcon "new-file.png" hiIconText "New"
        _checkable nil checked nil enabled
        t defAction nil actionList nil
        hiToolTip "New" hiStatusTip ""
    and so on. You can look at any of these fields (e.g. fileTB->schFileToolbarNew->hiToolTip)
    For your second question, look at <ICinstDir>/share/cdssetup/dfII/toolbars/byApplication/Layout.toolbars . You'll see the definition of Edit Snap Mode which refers to an actionList, each of which is declared as a subAction and has associated icons with each action. If you search in cdnshelp for "subAction" you'll get more info on how this works.
  • RK56
    I figured a similar way for problem 1. But I guess I have not mentioned clearly my problem 2. Let me re ask the question
    Background: A combo field will have an icon and a pulldown of subactions. Each subaction will have their own icons. Now I click the dropdown and pick a subaction. I want the icon on the combo field to change to reflect/notify the user what subaction has been selected. This is happening with Edit snap mode action list.
    Question: Should I manually modify the hiIcon of the combo field or is there any automatic process that changes the icon of the combo field according to the subaction?
    Ramakrishnan
    Hi Ramakrishnan,
    Got you - I didn't quite understand what you meant. There's no automatic process - the edit snap mode just updates the hiIcon (and hiTooltip). You can see this working if you get hold of the "Options" toolbar using the method I showed above and then do:
    optionsTB->lebEditSnapMode->hiIcon=optionsTB->lebEditSnapMode->lebEditDiagSnap->hiIcon
    Does that answer your question?
  • RK56
    Yes. Thanks for clarifying Andrew.
