  3. Issue in script to modify a routing blockage in Cadence...
  • Subscribers 150
  • Views 15977
Issue in script to modify a routing blockage in Cadence SKILL
elgunidy91
elgunidy91 over 10 years ago
I created 2 procedures in SKILL
The first takes 2 points "for ex: list(x:y)" and take a list of points returned by the command blockage_id~>points, and tries to find if those 2 points found on the returned list..
findPointsInList(pt1 pt2 ptList) .. returns 1 if successful or 0 otherwise
The second procedure uses the first one in its "if" condition, but it doesn't work, which is illogical to me!!
Hint: the many println() usages is for debugging.
Code:
;; Globals
deltaX = 0.02
deltaY = 0.02
offset = 0.02
cutWidth = 0.16
procedure( updateBlockage(id pts)
prog(
list1 list2 list3 list4 x1 y1 x2 y2 x3 y3 x4 y4 rectId idBlkgMetal1 blkgPointList vartop varbottom
x3TopBlkg y3TopBlkg x33TopBlkg y33TopBlkg x4TopBlkg y4TopBlkg x44TopBlkg y44TopBlkg
vartop = 0
varbottom = 0
list1 = list()
list2 = list()
list3 = list()
list4 = list()
blkgPointList = list()
arr=listToVector(pts)
list1 = arr[0]
list2 = arr[1]
list3 = arr[2]
list4 = arr[3]
pts=vectorToList(arr)
x1 = car(list1)
y1 = car(cdr(list1))
x2 = car(list2)
y2 = car(cdr(list2))
x3 = car(list3)
y3 = car(cdr(list3))
x4 = car(list4)
y4 = car(cdr(list4))
idBlkgMetal1 = id
blkgPointList = idBlkgMetal1~>points
;Top blockage;
x3TopBlkg = x3 + deltaX
y3TopBlkg = y3 + deltaY
x4TopBlkg = x4 - deltaX
y4TopBlkg = y4 + deltaY
x33TopBlkg = x3TopBlkg + offset
y33TopBlkg = y3TopBlkg + cutWidth
x44TopBlkg = x4TopBlkg - offset
y44TopBlkg = y4TopBlkg + cutWidth
;println("x3TopBlkg=")
;println(x3TopBlkg)
;println("y3TopBlkg=")
;println(y3TopBlkg)
;println("x4TopBlkg=")
;println(x4TopBlkg)
;println("y4TopBlkg=")
;println(y4TopBlkg)
;println("==========")
  ;;Top Blockage
  vartop = findPointsInList(list(x3TopBlkg y3TopBlkg) list(x4TopBlkg y4TopBlkg) blkgPointList)
  println("vartop = ")
  println(vartop)
  when(  equal( vartop 1 )
                println("Hi from top!")
                leChopShape( idBlkgMetal1 list(x33TopBlkg:y2 x33TopBlkg:y33TopBlkg x44TopBlkg:y44TopBlkg x44TopBlkg:y1) t t 10 )
                procedure(myFilterProc(objId)
                if(objId~>objType=="rect" t nil)
                rectId = gePointQuery( hiGetCurrentWindow() x3:y3 "myFilterProc")
                leStretchShape( rectId list( 0 cutWidth )
                list(nil t t nil) t )
                leStretchShape( rectId list(offset 0)
                list(nil nil t t) t )
                leStretchShape( rectId list(-offset 0)
                list(t t nil nil) t )
        );when
);prog
);proc
procedure( findPointsInList(pt1 pt2 ptList)
        prog( (pt1found pt2found flag1 flag2 sum cond1 cond2 cond3 cond4 cond5 cond6)
                sum = 0
                pt1found = 0
                pt2found = 0
                flag1 = 1
                flag2 = 1
                cond1 = 0
                cond2 = 0
                cond3 = 0
                cond4 = 0
                cond5 = 0
                cond6 = 0
                ;println("pt1found =")
                ;println(pt1found)
                ;println("pt2found =")
                ;println(pt2found)
                ;println("sum =")
                ;println(sum)
                foreach( pt ptList
                        ;println("pt =")
                        ;println(pt)
                        ;println("pt1")
                        ;println(pt1)
                        cond1 = equal(flag1 1)
                        cond2 = equal(float(car(pt)) float(car(pt1)))
                        cond3 = equal(float(car(cdr(pt))) float(car(cdr(pt1))))
                        cond4 = equal(flag2 1)
                        cond5 = equal(float(car(pt)) float(car(pt2)))
                        cond6 = equal(float(car(cdr(pt))) float(car(cdr(pt2))))
                        ;println("Blkg pt")
                        ;println(pt)
                        ;println("pt1 ")
                        ;println(pt1)
                        ;println("pt2")
                        ;println(pt2)
                        ;println(cond1)
                        ;println(cond2)
                        ;println(cond3)
                        ;println(cond4)
                        ;println(cond5)
                        ;println(cond6)
                        ;println("=========")
                        when( cond1 && cond2 && cond3
                                                ;println("I am section 1!")
                                                pt1found = 1
                                                flag1 = 0
                        when( cond4 && cond5 && cond6
                                                ;println("I am section 2!")
                                                pt2found = 1
                                                flag2 = 0
                        );when4
                );foreach
                sum = pt1found + pt2found
                ;println("after evaluation:")
                ;println(pt1found)
                ;println(pt2found)
                ;println("sum =")
                ;println(sum)
                if( equal( sum 2) then
                        return(1)
                else
                        return(0)
                );if
        );prog
);proc
I hope someone helps me.
Thank you!
Abdullah
  • skillUser
    skillUser over 10 years ago
    Hi Abdullah,
    I think that your main issue is that you are trying to compare floating point numbers using "equal" or '=' - this is never a good idea in any language. Use greater-than or less-than (> < greaterp lessp) functions, possibly combined with subtracting one number from another and looking at the absolute (abs) result and how close it is to zero (e.g. it is less than a very small number like 1e-6 in which case the numbers can be considered equal). Functions like pcRound() may help? There are many discussions about this in this forum and elsewhere, search for comparing floating point numbers as a starting place.
    Best regards,
    Lawrence.
  • Sheppy
    Sheppy over 10 years ago
    Hi Abdullah,
    I think Lawrence is right. It has to do with comparing floating point numbers. On numerous occasions I have ran into this problem and my solution to solve this "once and for all" is that before I do anything with a value (either a given value or a calculated one) is to round it to the design/database grid. I wrote a procedure which allows me to do it easily and always in the same way. It gives me control over the rounding too: either up, down or automatic rounding. I can even specify the accuracy of the rounding (which is by default set to the value Lawrence suggested: 1e-6 -> what are the odds of that!). Please have a look below for my code:
    ;;; spdk = abbreviation of our PDK name
    procedure( spdkPutOnGrid( value grid direction @optional ( accuracy 1e-6 ) )
        let( (  ( onGrid nil )
            ( theTest 0.0 ) )
            unless( fixp( value ) || floatp( value )
                error( "spdkPutOnGrid: argument #1 should be a integer or float - %L" value )
            ) ;;; end of unless
            unless( fixp( grid ) || floatp( grid )
                error( "spdkPutOnGrid: argument #2 should be a integer or float - %L" grid )
            ) ;;; end of unless
            unless( equal( lowerCase( direction ) "up" ) || equal( lowerCase( direction ) "down" ) || equal( lowerCase( direction ) "auto" )
                error( "spdkPutOnGrid: argument #3 should be a string, possible input: \"up\" or \"down\" or \"auto\" - %L" direction )
            ) ;;; end of unless
            unless( accuracy < 1.0
                error( "spdkPutOnGrid: argument #4 should be smaller then 1 (argument 4 sets the accuracy) - %L" accuracy )
            ) ;;; end of unless
            if( !zerop( value )
            then
                case( lowerCase( direction )
                    ( "up"
                        onGrid = atoi( sprintf( nil "%f" float( value / grid ) ) ) * grid
                        unless( abs( ( value - onGrid ) / value ) < ( grid * accuracy )
                            if( negativep( value )
                            then
                                onGrid = onGrid
                            else
                                onGrid = onGrid + grid
                            ) ;;; end of if
                        ) ;;; end of unless
                    ( "down"
                            then
                                onGrid = onGrid - grid
                            else
                                onGrid = onGrid
                            ) ;;; end of if
                        ) ;;; end of unless
                    ( "auto"
                        ;;; If value=12.75 and grid=0.1, the output should be 12.8
                        ;;; However, the output is 12.7. The calculation in the "theTest" statement
                        ;;; results in something slightly less than 0.5, so it would round-down...
                        ;;; Therefor, the third condition is added: if the difference is small relative
                        ;;; to the grid,
    the remainder is regarded as a half (0.5), thus round-up.
                        theTest = ( float( value ) - onGrid ) / grid
                        cond(
                            ( theTest == 0.0
                                onGrid = onGrid
                            ( theTest > 0.5
                            ( abs( ( theTest - 0.5 ) / theTest ) < ( grid * accuracy )
                            ( t
                                onGrid = onGrid
                        ) ;;; end of cond
                ) ;;; end of case
            else
                onGrid = 0
            ) ;;; end of if
            when( fixp( grid )
                onGrid = fix( onGrid )
            ) ;;; end of when
            when( floatp( grid )
                onGrid = float( onGrid )
            ) ;;; end of when
            ;;; Return the value...
            onGrid
        ) ;;; end let
    ) ;;; end of procedure spdkPutOnGrid
    This is how you use it:
    spdkPutOnGrid( 1.2345 0.01 "up" )
    -> 1.24
    spdkPutOnGrid( 1.2345 0.01 "down" )
    -> 1.23
    spdkPutOnGrid( 1.2345 0.01 "auto" )
    -> 1.23
    This is what you could do:
    ;Top blockage;
    dbGrid = 0.01
    rounding = "auto"
    x3TopBlkg = spdkPutOnGrid( ( x3 + deltaX ) dbGrid rounding )
    y3TopBlkg = spdkPutOnGrid( ( y3 + deltaY ) dbGrid rounding )
    x4TopBlkg = spdkPutOnGrid( ( x4 - deltaX ) dbGrid rounding )
    y4TopBlkg = spdkPutOnGrid( ( y4 + deltaY ) dbGrid rounding )
    Please try it, it will most likely solve your problem. It would also help to do the comparison like Lawrence suggests.
    With kind regards,
    Sjoerd
  • elgunidy91
    Thank you Sjored. I really appreciate your help!
  • elgunidy91
    Thanks Lawrence. It was a bit tricky to discover this!
