  3. hiCreateReportField... passing arguments to its callbac...
  • Replies 10
  • Views 22824
hiCreateReportField... passing arguments to its callback
trandolph
trandolph over 10 years ago
I am using hiCreateReportField and choosing the argument ?callback to find out which row
has been selected. The callback (as shown in the documentation for hiCreateReportField)
function is automatically passed two arguments. The first argument is the field name, the
second argument is a list of integers representing the selected items in the report.
My question is... How can I pass additional variables to my callback function while
keeping the two arguments passed automatically (fieldName selectedItems)?
Cadence doc...
reportField = hiCreateReportField(
...other arguments...
? callback 'reportCB
procedure( reportCB(fieldName selectedItems "sl")
  printf( "Report field callback, fieldName = %L, selectedItems = %L"           fieldName selectedItems )
    Andrew Beckett over 10 years ago +1
    This would never work: hiReportGetSelectedItems('theForm~>tabField~>page3~>tabInfo3) because the variable with the form is quoted and so not evaluated. Similarly: hiReportGetSelectedItems(theForm…
    Andrew Beckett over 7 years ago in reply to GP14 +1
    It's not entirely clear what you're trying to do, but I suspect you just want to update the contents of the report field? If so, alternating the ->choices list would do it: choices=abExampleTabForm-…
    There is a way using SKILL++ lexical scoping (using closures) to achieve this (in effect) - I describe a similar problem for ipcBeginProcess in this solution.
    However, in this case, I'm not sure where this additional argument is coming from - how would the report field callback know where to get it from? It might just be simpler to make the callback a string and then within the callback call hiReportGetSelectedItems().
  • trandolph
    Thank you that is what I need.... however when I try to execute I get a warning.
    Im probably not passing the argument correctly :/
    I have read the doc on hiReportGetSelectedItems().
    It is expecting one argument...
    Arguments
    g_reportField The report field.
    From my ciw...
    theForm~>tabField~>page3~>tabInfo3~>??
    (usedIn
    (scrollRegionStruct@0xb3883368 scrollRegionStruct@0xb38832c0) invisible t enabled
    t _justification left _labelIcon nil
    _labelOnly "..." fieldType labelOnly hiFieldSym
    tabInfo3 _activeUT nil modified nil
    lastValue "..." value "..."
    hiReportGetSelectedItems(theForm~>tabField~>page3~>tabInfo3)
    *WARNING* hiReportGetSelectedItems: only works on report field.
    nil
    nil
    Initially tabinfo3 is just a text field.... but when there are errors... i re-purpose it to a report field.
    my code...
    sprintf(title_str "Layout Hierarchical Check Report - %d errors" error_lay_hilo_number)
    hiDeleteField(theForm->tabField->page3 'tabInfo3)
    hiAddField(theForm->tabField->page3 list(hiCreateReportField(
    ?name 'tabInfo3
    ?title title_str
    ?titleAlignment 'center
    ?headers list(
    list("Layout cell name" 300 'left 'string t)
    list("Layer" 40 'left 'string)
    list("Purpose" 60 'left 'string)
    list("Voltage" 60 'left 'string)
    list(" X-coord" 80 'right 'float)
    list(" Y-coods" 80 'right 'float)
    ?choices error_lay_hilo
    ?selectMode 'single
    50:200 700:400 30)
    Am I not passing the argument correctly?
    Thanks again,
    -timr
    if the form is currently having a string field. However, if your code has switched across to replacing the field with a report field, then it would work fine.
    See the example below. If you run the code (using the line in the comment on the first line) and then go to the third tab. Click on Print Selections and it will show a message in the CIW saying it's a string field. If you click on the Add Field button first, then click on Print Selections you'll see info about whatever is selected.
    ; call hiDisplayForm(abCreateTabForm()) to see the example
    procedure(abCreateTabForm()
        let((tabField addField1 addField2 addField3 printSelections tabInfo1
                tabInfo2 tabInfo3)
            addField1=hiCreateButton(
                ?name 'addField1
                ?buttonText "Do nothing"
            addField2=hiCreateButton(
                ?name 'addField2
            addField3=hiCreateButton(
                ?name 'addField3
                ?buttonText "Add Field"
                ?callback "abAddField(hiGetCurrentForm())"
            printSelections=hiCreateButton(
                ?name 'printSelections
                ?buttonText "Print Selections"
                ?callback "abPrintSelections(hiGetCurrentForm())"
            tabInfo1=hiCreateStringField(
                ?name 'tabInfo1
                ?prompt "Info"
            tabInfo2=hiCreateStringField(
                ?name 'tabInfo2
                ?prompt "Info"
            tabInfo3=hiCreateStringField(
                ?name 'tabInfo3
                ?prompt "Info"
            tabField=hiCreateTabField(
                ?name 'tabField
                ?tabPlacement 'top
                ?value 1
                ?fields
                    list(
                        list(
                            list(addField1 100:0 200:30)
                            list(tabInfo1 0:30 540:30 100)
                        list(
                            list(addField2 100:0 200:30)
                            list(tabInfo2 0:30 540:30 100)
                        list(
                            list(addField3 100:0 200:30)
                            list(printSelections 320:0 200:30)
                            list(tabInfo3 0:30 540:30 100)
                ?tabs list("First" "Second" "Third")
            hiCreateAppForm(
                ?name 'abExampleTabForm
                ?formTitle "Tab Form"
                ?fields
                    list(
                        list(tabField 0:0 800:400 30)
                ?initialSize t
    procedure(abAddField(theForm)
        let((title_str (error_lay_hilo_number 3) (error_lay_hilo
            list(
                list("albert" "metal1" "drawing" "high" 1.0 2.0)
                list("george" "metal2" "drawing" "low" 3.0 1.0)
                list("harry" "metal3" "drawing" "low" -3.0 5.0)
            ?name 'tabInfo3
            ?title title_str
            ?headers list(
            ?selectMode 'single
            50:60 700:400 30)
    procedure(abPrintSelections(theForm)
        if(theForm->tabField->page3->tabInfo3->fieldType=='report then
            printf("SELECTIONS ARE: %L\n"
                ; I'd probably use -> rather than ~> but it doesn't matter
        else
            printf("FIELD IS CURRENTLY A STRING FIELD\n")
  • trandolph
    trandolph over 9 years ago
    Hello Andrew,
    Sorry for the late reply. Thank you that is indeed what I need.
    As usual it was my code. I loaded it into IDE set a few break points
    and saw what I was doing wrong.
    Thanks again for taking the time to educate... its really appreciated.
    -timr
  • rajoli
    rajoli over 7 years ago in reply to trandolph
    Whenever user press column header in report filed we need to callback function for  that.
    How to implement that logic.
    Rajoli
    Andrew Beckett over 7 years ago in reply to rajoli
    Hi Rajoli,
    You do that with the ?sortCallback argument to the hiCreateReportField - this is then a function that gets called with which column is to be sorted (i.e. which you clicked) and the sort direction. See the documentation for more details.
  • GP14
    GP14 over 7 years ago in reply to Andrew Beckett
    I am trying to re-do this code so I can create a Tab which has a function of adding and entry of information in the table.
    Is it possible in here skill? Its just like displaying information in every the selected entry
    For example there exists this table like the table shown above.
                list( "LMARK" "metal1" "drawing" "high" 1.0 2.0)
    I would like to add an entry in the list. When I select another layer the data will be added to the list. See image below.
                 list( "met1" "metal1" "drawing" "high" 1.0 2.0)
    *WARNING* hiDeleteField: field tabInfo3 is not in scroll region page1
    *WARNING* hiAddField: Cannot add non-unique field symbol to fieldList - tabInfo3
    I try to use the logic of after using the addField I will use the DeleteField to erase the old field but then I got some warning like the * above.
    Thanks for the help.
    -GP14
    choices=abExampleTabForm->tabField->page3->tabInfo3->choices
    abExampleTabForm->tabField->page3->tabInfo3->choices=cons(list("met1" "metal1" "drawing" "high" 1.0 2.0) choices)
  • GP14
    Basically you are right about what I meant in  this case.
    I try your suggested inputs in the code above but I did not get the right location where it will be place. I try to put it in the abAddField and change the error_lay_
    hilo into "choices" (this is the variable that you gave in your reply to our latest conversation) the next line that you gave I input it after hiCreateAppForm.
    Do I missed something about the code?
    For an instance I want my report field to be blank, then after I click add button it will be added to the report field then it gets updated after every add.
    Thanks for the help Andrew.
    GP14
  • GP14
    GP14 over 7 years ago in reply to GP14
    Its now done.
    Thanks!
