  3. bindkey to move selected object
  • Views 21240
mctang
mctang over 10 years ago
Hi All,
I want to create my own bindkey to use key 5/6/7/8 to move a select object left/right/up/down, and the moving distance is 0.005 upon each key-pressing.
eg, if I press key ‘5’, the selected(highlighted) object will move up 0.005, press ‘6’ will move it down 0.005, etc.
Currently in Virtuoso, we can only move the object by dragging the mouse.  But I’m used to use bindkey in other layout tools, and I want to do the same in Virtuoso.
I myself tried following , but it didn’t work (it always popped out Move window which I do not like) :
procedure( leMoveObj(deltx delty)
    leHiMove()
    le0MoveForm->moveXField->value=deltx
    le0MoveForm->moveYField->value=delty
    _leApplyDeltaCB(hiGetCurrentWindow())
hiSetBindKey("Layout" "<Key>5" "leMoveObj(-0.005 0)")
hiSetBindKey("Layout" "<Key>6" "leMoveObj(0.005 0)")
hiSetBindKey("Layout" "<Key>7" "leMoveObj(0 0.005)")
hiSetBindKey("Layout" "<Key>8" "leMoveObj(0 -0.005)")
Any suggestion ?
ManChak
  • RK56
    RK56 over 10 years ago
    Hi ManChak
    You can try with hiReplayFile and put all the commands related to form like invoking the form, entering x and y fields and pressing ok or apply in the form.
    Having said the above, your way for moving objects is not my favorite.
    • I have created a toolbar with direction buttons and delta XY entries.
    • Or you may use non HI procedures like leMoveFig or leMoveObject
    • Or Instead of move function you can try with Stretch. Advantage with stretch is that if a object is fully selected, it moves else it stretches.
    • Or You may use cadence's dx and dy by pressing TAB button
    Ramakrishnan
    I agree with Ramakrishnan. Something like:
    procedure(MyMoveSelected(deltax deltay)
      let((xform)
        xform=list(deltax:deltay "R0" 1)
        foreach(obj geGetSelSet()
          dbMoveFig(obj nil xform)
    The above is untested, but it would be something like that to move all the selected objects.
  • mctang
    Hi Andrew and Ramakrishnan,
    Thank you for your suggestions. I modified Andrew 's code "dbMoveFig(obj nil xform)". It works well now. (Moderator note: corrected Andrew's original code to add the missing argument)
    ManChak
  • Rakesh 25
    Rakesh 25 over 6 years ago
    What is the purpose of this syntax  " le0MoveForm"    I tried searching in API finder but Im not able to find.
    Please can explain exactly what does this line do
    Andrew Beckett over 6 years ago in reply to Rakesh 25
    Well, as described in the thread above, this is not a terribly good way of doing it because it depends on the interactive forms having been run. What has happened here is that the original poster will have used the interactive move command in the layout editor, and typed in values on fields on the form - and then captured the commands in the CDS.log (and the CIW if the log filter settings are set appropriately) which record how the form was filled in. In general we don't document those - they're there to enable replay of the log file in the same conditions. In this case the form has a number as part of it - I think (if I remember rightly) this is because we keep the form unique for different technologies (may be for different windows - I didn't check).
    Anyway, the point is that this is precisely why you don't want to be using this approach to do your automation, as it relies on both undocumented behaviour, and also potentially the form name may change depending on what you've done before. Hence the suggestion to use the dbMoveFig approach.
