  3. Hierarchical copy with prefix and pcells
  • Views 17354
Petya
Petya over 10 years ago
I need to do a Hierarchical copy of top level design with a prefix. I tried using Solution Article 11807102, but the problem is the design has some pcells in the hierarchy that seem to be repeating, and are randomly placed in different libraries so I cannot add them to a skipLibs list. So either the script doesn't work because they are repeating layouts or it doesn't work because I'm trying to copy and rename a pcell.
I was wondering is there a way to exclude the pcells the same way i'm excluding some of the libraries. I tried excluding them by  cv~>isParamCell, but the problem is the ccpExpandDesign used to create the spec already has those layouts too and it doesn't seem to work, just crashes the ccpCopyExactDesign. I tried also not using ccpExpandDesign, and creating the spec manually from all the subcells, but that gave the same result.
I'm probably doing something very wrong, because I'm running out of ideas.....
Thanks in advance!
Petya
    The trouble is that the code is using ccpCopy and so doesn't see the database objects of the cellViews themselves.
    Sorry for that short reply - I was having trouble posting what I wanted. I'd suggest contacting customer support, because I don't have the bandwidth to rewrite the solution (written by somebody else).
    The solution may be to use ccpExpandDesign to collect the cellViews, and then open each using dbOpenCellViewByType and filtering out those which are pcells.
  • Petya
    Thank you! This is what i actually tried, but i'm struggling to find a way to remove the filtered ones from the specList, so I just continue getting the ccpCopy error. I couldn't find anything that works for actually getting rid of a spec or two :)
    Sorry for the stupid question, but how do I contact customer support? I've never done it :) Still hoping I could figure it out...
    Kind Regards,
    Petya
    Petya,
    You probably need to create a new spec list and then iterate through the existing spec list, and either add a spec to the new spec list or not depending on whether it's a PCell. Don't think there's a function to delete a spec from a spec list.
    To access customer support, cast your eyes upwards (on the forum web site) to the top of the page, where there's a fairly large "Support" link in the very top row. Alternatively go to
    Normally I make my mentions of "customer support" a hyperlink but I was having problems replying to your post earlier for some reason, so I omitted it. The many hundreds of other references to customer support I've made in posts tend to have the link though.
