  3. How to copy iopin in schematic view
  • Views 15195
San
San over 10 years ago
Hi ,
I have a schematic view in which I just have one InputOutput pin celled "gate"
I just want to make a copy of that pin and place it little farther.
I  used following code but it did not copy it properly.
schId = geGetEditCellView()
geSelectAll()
foreach(fig selectedSet()
  dbCopyFig(fig schId list(0:4 "R0" 1))
I will appreciate your help on this.
Sanket
    Two problems - first there's a textDisplay you don't really want to copy, and secondly, dbCopyFig will just copy the pin instance, and not make the new object a pin. Simplest solution is:
    geSelectAll()
      unless(fig~>objType=="textDisplay"
        schCopy(fig schId list(0:4 "R0" 1))
    Hope that helps. The schCopy is a bit of a higher level function, so understands that it's a pin. Avoided reinventing the wheel yourself...
  • San
    This is exactly what I was looking for. It worked like charm.
    Thanks a lot Andrew.
    Sanket
