  3. dbDeleteFigGroup is undefined function?
  • Views 15445
RVERP
RVERP over 10 years ago
This function is referenced in the manual, but it doesn't work (not a function??)
Is there any other way to delete a figGroep?
    The function is only documented in the ITKdb documentation (the Integrator's Toolkit Database Reference). This is the C API, and so it's not a SKILL API you've seen.
    To delete a figGroup, simply use dbDeleteObject(), passing the figGroup object.
  • RVERP
    I see, thanks Andrew.
