  3. Unknown error - bad window
  • Views 3465
JMPerdomo
JMPerdomo over 10 years ago
Hi, I am having some trouble understanding this error that I am having.
*WARNING* bad window(0x2326f150): not on window list
*Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
*WARNING* (GE-2042): An unexpected error occurred while applying uifPushGlobalCDFState SKILL function.The reported error is : nil.
(nil)
I think it is realated to skill that I use that who closes some windows.
Can you help me out?
    Which version (subversion) are you using? getVersion(t) will tell you this (or Help->About in the CIW).
    I found a whole bunch of reports of this error from IC617 which were resolved in IC617 ISR2 (IC6.1.7-64b.500.2). Maybe it's a different problem though. Note that this would also affect ICADV12.2 and would be fixed in ICADV12.2 ISR2.
  • JMPerdomo
    The sub-version is IC6.1.6-64b.500.14.
    Do you know if there is any way to workaround the issue?
    No, but then again, I'm not sure whether what you're seeing is the same issue. The other reports were specific to particular forms and only in IC617. So it may be something wrong with your custom code.
    The right thing to do here is to contact customer support. Then we can see if there's an error in the SKILL code which is causing this.
  • JMPerdomo
    Thanks for you help Andrew,
    I will take your advice and try to contact customer support.
    Regards
