  3. CIW error messages for SKill script
  • Views 16803
Inas Mohammed
Inas Mohammed over 10 years ago
I have a sample skill script, on running it gives an error message in the CIW.
Here is the Code:
procedure(place_devices(cellView devLib devCell Length nfunit wfunit DUM1nf DUM1wf DUM2nf DUM2wf yPitch Pattern)
let((params array nRows nCols Type dev name nf wf inst devCounts x y xPitch (x0 0.0) (y0 0.0))
devCounts=makeTable('DEVCOUNT 0)
array = listToVector(foreach(mapcar row reverse(pattern) listToVector(parseString(row " "))))
nRows=length(pattern)
y=y0
for(row 0 nRows-1
x=x0
nCols=length(array[row])
for(col 0 nCols-1
dev=array[row][col]
devCounts[dev]++
name=sprintf(nil "%s.%d" dev devCounts[dev])
Type=cond(
(eq('M getchar(array[row][col] 1)) 'device)
(zerop(row) && (zerop(col) || col==nCol-1) 'corner)
(zerop(col) && (zerop(row) || row==nRows-1) 'corner)
(zerop(row) || row==nRows-1 'topBottom)
(zerop(col) || col==nCols-1 'leftRight)
(t 'dummy)
caseq(Type
((device dummy)
nf=nfunit
wf=wfunit
(corner
nf=DUM1nf
wf=DUM2wf
(topBottom
nf=DUM2nf
wf=DUM2wf
(leftRight
nf=DUM1nf
wf=DUM1wf
(t error("type=%l\n" Type)
params = list(
list("l" "string" aelSuffixNotation(1u * Length))
list("wf" "string" aelSuffixNotation(1u * wf))
list("fingers" "string" sprintf(nil "%d" nf))
list("routePolydir" "string" "Top")
) ; params
when(zerop(col)
; Device is on left edge. Add detached bodytie.
params = xcons(params
list("bodytie_type" "string" "Detached"))
when(col==nCols-1
; Device is on right edge. Add detached bodytie.
list("bodytie_typeR" "string" "Detached"))
inst=dbCreateParamInstByMasterName(cellView devLib devCell "layout" list(x y) "R0" params)
xPitch = nf * (Length + 0.1) + 0.12
;; TODO: Replace numbers with space/extension params
;; Or, use rodGetObj and/or M1 geometry of the
;; inst->master cellView to calculate the xPitch
;; of the instantiated device
;; Calculate x coordinate for next device
x = x + xPitch
)) ; let ; procedure
place_devices(
geGetEditCellView() ; cellView
"tsmcN65" ; devLib
"pch" ; devCell
0.2 ; Length (um)
2 ; nfunit
6.0 ; wfunit (um)
2 ; DUM1nf
6.0 ; DUM1wf (um)
2 ; DUM2nf
2.0 ; DUM2wf (um)
1.0 ; yPitch (um)
list(
"Du Du Du Du Du"
"Du M1 M2 M1 Du"
"Du M2 M1 M2 Du"
"Du Du Du Du Du"
) ; pattern (rows)
here is the message in the CIW for the highlighted line above:
*Error* dbCreateParamInstByMasterName: argument #6 should be a list (type template = "dggggltxlg") at line 67
Can you please tell me what is the issue with that? how can i define the orientation in a list?
Regards
    OK, the answer here is to read the manual. Given the error message, I would have thought that would have been an obvious first step, rather than posting in a forum!
    Your line of code:
    The documentation for this function (the first part, at least):
    d_cellView
    t_libName
    t_cellName
    t_viewName
    t_name
    l_origin
    l_orient
    [ x_numInst
    [ l_params
    [ g_physOnly ] ] ]
    => d_inst / nil
    You have omitted the instance name (t_name). That should be the fifth argument. You also need to specify x_numInst before the list of parameters (if providing the parameters). Specify this as 1.
  • Inas Mohammed
    Ok thanks alot
  • RK56
    RK56 over 10 years ago
    Is this is the technique to get unique instance name? (by specifying 1). I had struggled a lot in the past to get unique instance name.
    Later on found a way to do. (just length of total number of instance + 1)
    Ramakrishnan
  • RK56
    I guess I had misread your reply. Never mind.
    -Ramakrishnan
    If you'd read the documentation, you'd see that you can specify the instance name argument as nil and then it will automatically come up with a unique instance name.
