  3. ADE/ADEXL PCell instance params
  • Views 580
Ionutz
Ionutz over 10 years ago
 I have created a PCell for the Schematic/Symbol views which takes in user parameters (example: noDevices).
I am using the above PCell in my schematic hierarchy and provide different values for the parameter for the different instantiations.
 How can I access the value of the parameter for specific instances after the ADE/ADEXl simulations in order to do further post-processing of results?
 What I am trying to do is create a user function called "getNoDevices" that takes in as input the hierarchical path to the instance (form the running testbench) and dumps out the value of the parameter.
That way, in ADE/ADEXL I can reuse that value... any ideas? :(
 Thank U,
Ionut
