  3. binding a layout to schematic and putting pins in the l...
  • Views 20349
binding a layout to schematic and putting pins in the layout
Inas Mohammed
Inas Mohammed over 9 years ago
I have a script which generates a layout transistor pattern.
Then i needed to bind this layout to a schematic in order to have it XL happy.
I searched in the older links here and i found these functions: lxSetConnRef & bndSetInstsBindingByName.
And i searched for them in the manuals to know how they are used, I found that i have to use "lxSetConnRef" first then use the second function. both functions have the condition to have the instances as leaf one, what does it mean??????
I tried that and it worked nicely with the transistor has only one multiplier, but it couldn't work with the other transistors which have more than one multiplier.
So can you please tell me:
1) what is meant by leaf instance?
2) How can i make it for transistors consisting of more than one multiplier?
About putting the pins in the layout, i thought about it like the following: i just made some brain storming with my self about that.
- determine the pins needed to be placed, and their layers (text and box)
- Identify every transistor will be connected to which pins.
- for a certain transistor, identify their Drains, sources, and gates will be connected to which pins and place them.
- check if this transistor if its a dummy so all their terminals will be set to vdd.
So please can you tell me what the followed procedures for placing the pins for a pattern using skill script, if you can give a simple sample code it will be nice
Inas
    Inas,
    A leaf instance simply means that this is not a hierarchical instance (on the schematic side, primarily). In other words, if you have a hierarchical design with an instance of a block called I1, you can't bind everything in that block in one go - you've got to go down to the individual components.
    For binding one to many (e.g. m-factor) devices, you can either use:
    bndAddInstsBindingByName(schCv "M1" layCv "I1")
    bndAddInstsBindingByName(schCv "M1" layCv "I2")
    bndAddInstsBindingByName(schCv "M1" layCv "I3")
    etc. You may get warnings until you've bound enough instances. You can also use bndSetInstsBindingByName for the first call, but only the first for a particular schematic instance.
    Or you could use bndSetObjectsBinding:
    bndSetObjectsBinding(schInstId list(layInstId1 layInstId2 layInstId3))
    i.e. you use the database id of the instances instead, and pass a list for the  layout side.
    I can't really write your  pin placement code for you, sorry.
  • Inas Mohammed
    Thanks Andrew for your answer.
    About the pins placement, during my searching about how to place the pins, i found that once the schematic and layout becomes bounded the pins can be put easily on every instance in the layout depending on the connectivity, correct?
    I just need you help on guiding me how to achieve that, please.
    Inas
    I have no idea what you mean. Why would you want to put pins on every instance?
  • Inas Mohammed
    Ok
    I have written a sample skill script to bind between certain schematic and layout.
    M7: is one multiplier.
    M6: 4 multipliers
    M9: 8 multipliers
    This script worked fine with M7 and i can highlight it in the layout when selected in the schematic. But when it works on M6 it gives an error telling that there is no M6.5 in the layout.
    From this error i deduced that i need to check for the value of idx after its incremented either it is equal to length of x or not. Can you please tell me how to do that?
    I need to check if idx=length(x) if yes still inside the inner loop, if no, exit the inner loop and go to the outer loop. Can you tell me how to write this part in the script please?
    Here it is:
    procedure(bind_inst(schCV layCV instList)
    let(( (idx 1) )
    lxSetConnRef( "current_mirrors_skill" "CM_UPPER" layCV "CELLVIEW" ?schLib "current_mirrors_skill" ?schCell "CM_UPPER"
    ?schView schCV )
    foreach(instName instList
         bndRemoveInstBindingByName(schCV instName)
            foreach(x setof(inst layCV->instances strncmp(inst->name instName 2) == 0)
                            bndAddInstsBindingByName(schCV instName layCV sprintf(nil "%s.%d" instName idx))
                                idx++
    bind_inst(dbOpenCellViewByType("current_mirrors_skill" "CM_UPPER" "schematic_trial")
    dbOpenCellViewByType("current_mirrors_skill" "CM_UPPER" "layout_skill3_xlclean") '("M7" "M6" "M9"))
