  3. Require Run time creation of unique Radio buttons
  • Views 15042
JPBharti
JPBharti over 9 years ago
I am trying to develop a GUI where the number of radio buttons will be decided once the script is run. I need to have these run time formed radio button symbols matched to a list of pin names(string type, maybe here I can use a table), so that I can do some operation when a particular radio button is selected.
I am writing down the code snippet :
myPinTable=makeTable("PINTABLEKEY" "PINTABLEVALUE")
terminalsList =car(geGetSelectedSet())~>master~>terminals~>name
numTerminals=length(terminalsList)
; radiosymbolfield creation
for(i 1 numTerminals
radiosymbol=gensym(strcat("radio" pcExprToString(i)))
myPinTable[nthelem(i terminalsList)]=radiosymbol           ; Mapping terminals names to corresponding radio symbols
radioList=list(hiCreateRadioField(
?name radiosymbol
?prompt nthelem(i terminalsList)
?choices list("Yes" "No")?
?defValue "No"
)    20:(70+(20*i)   200:(70+(20*i))    200)
There is also another boolean field(Select_All) when enabled will change the state of all radio buttons to "Yes". Below procedure is mentioned as the callback function of the boolean field. PINLISTFORM is the symbol for the AppForm.
procedure(selectionAll(terminalsList myPinTable)
PINLISTFORM~>Select_All~>value=t
PINLISTFORM~>Select_None~>value=nil
foreach(elem terminalsList
PINLISTFORM~>myPinTable[elem]~>value="Yes"
);proc
When I run the script, I get the following error and the AppForm does not pop up.
*Error* arrayref: can't handle nil["ithermn20_b"]
If I comment out the selectionAll procedure and remove the callback in the boolean field. I can see the form getting defined and displayed. Can someone tell me where am I going wrong in the implementation?
Jay
  • dmay
    dmay over 9 years ago
    You can't access the value this way:
    You can try it this way:
    get(PINLISTFORM myPinTable[elem])~>value="Yes"
    Also, the second value to the makeTable command is the default value for table items. Thus, if you access an element that has not explicitly been added to the table, you'll get a value back. You used "PINTABLEVALUE". Maybe this is what you want. I often use nil so I can easily do an existence check like: when(myPinTable[elem]
    Derek
