  3. Opening a process for amsDmv
  • Subscribers 148
  • Views 3343
FormerMember
FormerMember over 9 years ago
Hello people,
I've been asking vague questions lately, I swear this will be different :D
I'm running the following pseudo code:
Call_amsDmv() ;amsDmv is called with a skill script to run without GUI and without forcing virtuoso to exit. (no -exit command in the script).
Check_the_results() ;This parses the output "rep" file and search for the verdict on the comparison
repeat_for_every_cell() ;A simple foreach loop that contains the last two steps
That being said, the problem is that the whole flow seems to halt amsDmv from saving the .rep file. Which prompts an error in the check step because it calls on a file that doesn't even exist yet! I tried to perform some wait cycles between the first and the second to give enough time for the file to be saved, but that doesn't happen. It just waits and gives the error and then the file gets saved. It appears to me that whatever I do, it WILL stop the amsdmv from saving the file. I don't know why but it looks like that. So I'm thinking about opening something like child processes that doesn't finish unless the file is saved or something.
Would ipcSkillProcess save me? If yes, how to use it? I have no clue here!
Sherif
