  3. Create Constraint in skill
  • Views 16504
WTony
WTony over 9 years ago
I'm trying to modify some constraint in the techfile read only. I think to use skill code to make the changes in Virtual memory.  I found those two skill command cstCreateConstraint and cstDeleteConstraint.  when I try the cstCreateConstraint, it's gives me an error message
*Error* cstCreateConstraint: (CST-5160): The values entered do not match the allowed value types for this constraint allowedCutClass. Valid value types are (Int2DTblValue ).
does anyone have some example syntax with "Int2DTblValue"
those are the code I used
  techID = techGetTechFile(ddGetObj("TechLib"))
  cgID = cstFindConstraintGroupIn(techID "CG_VIA2")
  cstCreateConstraint(cgID "allowedCutClass" "VIA2"
               list('('("width" "width2"))
                 '('(0.0 0.0) 1
                  '(0.03 0.0) 0
               list('(lowerlayer "M1")
                 '(uppeerLayer "M2")
                 '(cutClass "square")
               t t)
Thanks for help
  • WTony
    sorry, I did a type error. Error message is still apply
    cstCreateConstraint(cgID "allowedCutClass" list("VIA2")
    '('(0.0 0.0) 1
    '(0.03 0.0) 0
    '(upperLayer "M2")
    t t)
  • WTony
    I found what's going wrong
    I replace " ' " by list and it works
    list(list(list("width" "width2"))
    list(list(0.0 0.0) 1
    list(0.03 0.0) 0
    list('(lowerLayer "M1")
    '(upperLayer "M2")
    t t)
    I don't know the difference between ' and list. I'm still a novice in skill.
    If you use the quote operator ('), it stops everything after it (to the matching parenthesis) from being evaluated - you are just specifying literal values. So it doesn't make sense to put quoted lists inside quoted lists, otherwise the quote is not evaluated.
    If you use the list() function, all the arguments are evaluated before the list is created.
    If you do:
    a=1
    b=2
    '(a b)   ; this will be (a b)
    list(a b)   ; this will be (1 2)
  • WTony
    thanks Andrew for the clarification
