  3. How to enforce schematic rule checker
  • Views 16310
twen
twen over 9 years ago
Is there any way that I can ask the admin to put a piece of skill code in the library to enforce the following schematic rules?
1. Set all Verilog AMS Check rules to error in the Schematic Rules Checks Setup form and disallow users from changing it.
2. Force users to give a net or an instance an explicit name instead of the default net1234 or I1234 names.
3. Force users to use little endian bus notation B<msb:lsb> and lsb is always 0, i.e. B<5:0> is valid but not B<6:1> nor B<0:5>.
4. Force users to choose or avoid the pin/net/instance names from a customized pattern list.
I am using "@(#)$CDS: virtuoso version 6.1.6-64b 12/07/2015 20:18 (sjfbm186) $"
Thank you,
TJ
    Some of these things can be partly done via cdsenv variable settings:
    1. These can be done with schSetEnv("checkSupportAMS" t) to turn the section on, and then:
      envSetVal("amsDIrect.vlog" "allowIllegalIdentifiers" 'cyclic "no")
      envSetVal("amsDIrect.vlog" "allowNameCollisions" 'cyclic "no")
      envSetVal("amsDIrect.vlog" "allowDeviantBuses" 'cyclic "no")
      envSetVal("amsDIrect.vlog" "allowSparseBuses" 'cyclic "no")
      I don't believe you can disallow users from changing the settings though.
    2. Maybe this could be done with:
      envSetVal("schematic" "srcNetNameExpr" 'string "whatever") ; need to write a regular expression
      envSetVal("schematic" "srcNetNameSyntax" 'cyclic "error")
      Similarly srcInstNameSyntax/srcInstNameExpr.
      However, it might need writing some SKILL code
    3. This I think needs some SKILL code
    4. This might be the regular expression syntax as in point 2 (also srcTermNameSyntax/srcTermNameExpr). However, probably a SKILL trigger.
    For the SKILL code approach, see this example in a previous post.
  • twen
    Hi, Andrew,
    Thank you for the naming convention skill code template. I'll see if the skill code can be more effective than the guidelines and rules on a piece of paper that everyone throws away.
    TJ
