  3. Can I draw a reference line in virtuoso?
  • Views 19208
richardyuan
richardyuan over 9 years ago
I mean a reference line that do not use drawing layer and do not stream out to GDS, just a line for reference.
The ruler is OK, but I don't like the numbers and segments, I just want a pure line.
Is there any skill function to do that?
    A couple of approaches. One would be to use dbCreateLine, and then create it on a layer-purpose that is not streamed out. Another one is to use:
    dbCreateMarker(geGetEditCellView() "Reference Line" "Experiment" list(0:0 10:4) nil t nil)
    and maybe:
    pteSetVisible("Markers" t "Objects")
    to ensure they're visible by default. You can then see them in the annotation browser too - I just made the message "Reference Line" and the tool "Experiment" - but you can play with that of course.
  • richardyuan
    This is really helpful hints. Thank you, Andrew.
    And I want furthermore a ruler-like behavor for my action:
    When I click one point in the cellview, it can give a line-handler ready to move around, then when I move the mouse and click another point, the handler released and a line is draw between the two points.
    Can this be realised in skill script?
    How about this?
    /* CCFenterRefLine.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 02, 2016
    Modified
    By
    Example of a enter function to prompt you to enter two points,
    and then to create a marker as the result. Might want to use:
    to ensure they are visible.
    Call CCFenterRefLine() to prompt the user to create the marker line.
    SCCS Info: @(#) CCFenterRefLine.il 12/02/16.10:03:27 1.1
    procedure(CCFenterRefLineCB(wid ok points)
        let((cv)
            when(ok && wid
                cv=geGetEditCellView(wid)
                dbCreateMarker(cv "Reference Line" "CCFenterRefLine"
                    points nil t nil)
    procedure(CCFenterRefLine()
        enterLine(
            ?prompts list("Enter first point" "Enter second point")
            ?wantPoints 2
            ?doneProc "CCFenterRefLineCB"
            ?cursor hicTCross ;hicCreateRulerEdge
  • richardyuan
    Thank you, Andrew, It works fine.
