  3. How to check if a tool, partition, and variable are registered...
  • Views 17017
How to check if a tool, partition, and variable are registered before envSetVal?
drdanmc
drdanmc over 9 years ago
Is there a way to protect calls in a .cdsinit to envSetVal with something that makes sure the tool, partition, and variable are available to be set?  For example, if you launch the QRC gui (qrcui from command line) it will load your .cdsinit but doesn't like envSetVal calls for "layoutXL" (for example).  I can protect functions with things like:
when( isCallable('calRegisterSpecialFunction)
  calRegisterSpecialFunction(....)
The envSetVal calls just cause warnings which can be ignored but it makes me feel better to not have lots of warnings all the time.
-Dan
  • skillUser
    skillUser over 9 years ago
    Hi Dan,
    I think that 'envIsVal' is what you are looking for, e.g.
    envIsVal("layoutXL" "autoArrange")
    => t
    envIsVal("layoutXL" "autoOrange")
    => nil
    You could potentially wrap this in a function or even in a macro. I hope that this helps!
    Lawrence
  • drdanmc
    Perfect! Thanks so much.
  • skillUser
    Here's my attempt at a macro for this called "envSetValSafe":
    (defmacro envSetValSafe (tool var type val) `(when (envIsVal ,tool ,var) (envSetVal ,tool ,var ,type ,val)))
    envSetValSafe("layout" "drawDottedGridOn" 'boolean t)
    => t
    envSetValSafe("schematic" "madeItUp" 'boolean t)
    => nil
    (expandMacro `(envSetValSafe "layoutXL" "autoArrange" 'boolean nil))
    => when(envIsVal("layoutXL" "autoArrange")
        envSetVal("layoutXL" "autoArrange" 'boolean nil)
    You would still need to get the 'type' argument correct.
    Lawrence.
    Lawrence (once an AE, always an AE ;-> ),
    I should point out that there's no need for this to be a macro. A simple function would do - in general macros should only be used when you really need them (although this has conventional function call semantics). So it could have just been:
    procedure(CCFenvSetValSafe(tool var type val)
      when(envIsVal(tool var)
        envSetVal(tool var type val)
    (good to have a prefix so that you know who to blame when something doesn't work).
    **Pedantry alert**. Let me give a slight convoluted reason as to why it wouldn't be a good idea to have this as a macro:
    a="auto"
    envSetValSafe("layoutXL" a=strcat(a "Arrange") 'boolean t)
    This would expand to:
    when((envIsVal "layoutXL"
        (a = strcat(a "Arrange"))
      (envSetVal "layoutXL"
       'boolean t
    so the variable you set wouldn't be the same as the variable you queried. I know this is fairly unlikely, but you have to be careful when you reference the same argument twice in a macro definition. The function version wouldn't have this side effect.
