  3. How to create string with backslash in it?
  • Views 15600
navyapilli
navyapilli over 9 years ago
Hello Experts,
I'm trying to build a string which has "\" backslash in it but I'm not able to achieve this.
Example:
My end goal is to make this string: "myItem->abc->\&Simulation15->myChoice=t"
Where number 15 is passed through a variable.
say myNum = 15
So I'm trying strcat("myItem->abc->\&Simulation" sprintf(nil "%L" myNum)  "->myChoice=t")  but this is erroring out due to backslash character.
I tried using escape character and some other ways but not able to make the string as required.
Any help would be appreciated.
Navya
  • skillUser
    skillUser over 9 years ago
    Hi Navya,
    precede the backslash with another backslash i.e. "\\" -> "\". If the '&' needs escaping too then you would need three backslashes: "\\\&" -> "\&", but I think you only need two in this case. Also, you can create the whole string from 'sprintf' without needing to use 'strcat' also, something like: sprintf(nil "myItem->abc->\\&Simulation%d->myChoice=t" myNum)
    Best regards,
    Lawrence.
