  3. Streaming and merging two gds files
  • Subscribers 150
  • Views 19214
archive over 18 years ago
Hi I was wondering, is there a way to script streaming in two gds files, instantiating one top cell into the other one and then streaming out? I would like to automate dummy metal fill addition to a design. Simon
Originally posted in cdnusers.org by sclemow
    Hello sclemow,
    Below you can find the SKILL script to merge to cells.
    You will need to modify the parameters , cell names, library names etc according to your requirements. I have marked these the code with <> statements.
    1. First it streams in the GDS1.gds and GDS2.gds files into LIBRARY1 and LIBRARY2.
    2. Then, it creates a new library NEW_MERGED_LIBRARY, creates a new cell and instantiates LIBRARY1 and LIBRARY2 top cells within this cell. Then, it streams out the merged cell.
    Hope this helps. ;-)
    ; Create LIBRARY1 and stream in GDS1
    ddsHiCreateLibrary()
    ddsCreateLibForm->LibName->value = ""
    ddsCreateLibForm->Option->value = "Attach to an existing techfile"
    hiFormDone(ddsCreateLibForm)
    tcNewLibAttachTechForm->tcBinaryTFLibCyclic->value = ""
    hiFormDone(tcNewLibAttachTechForm)
    pipoDisplay(transStreamInForm)
    transStreamInForm->pipoLibName->value = ""
    transStreamInForm->pipoInFile->value = ""
    transStreamInForm->pipoScale->value = 0.001
    transStreamInForm->pipoTechfileName->value = ""
    hiFormDone(transStreamInForm)
    ; Create LIBRARY2 and stream in GDS2
    ; Create a new library to hold the merged GDS
    ; Attach the new library to the tech file
    deNew()
    deNewForm->deLibName->value = ""
    deNewForm->deCellName->value = ""
    deNewForm->deViewName->value = "layout"
    deNewForm->deToolName->value = "Virtuoso"
    hiFormDone(deNewForm)
    ; Create a new cell in the new library and instantiate the other cells to be merged
    cv = dbOpenCellViewByType("" "" "layout" "maskLayout" "w")
    dbCreateInstByMasterName(cv "" "" "layout" "I0" list(0 0) "R0")
    dbCreateInstByMasterName(cv "" "" "layout" "I1" list(0 0) "R0")
    dbSave(cv)
    dbClose(cv)
    ; StreamOut
    pipoDisplay(transStreamOutForm)
    transStreamOutForm->pipoLibName->value = ""
    transStreamOutForm->pipoPrimaryCell->value = ""
    transStreamOutForm->pipoViewName->value = "layout"
    transStreamOutForm->pipoScale->value = 0.001
    transStreamOutForm->pipoOutFile->value = "NEW_TOP_CELL.gds"
    hiFormDone(transStreamOutForm)
    Originally posted in cdnusers.org by kanwarsr
