  3. launch batch of sims with OCEAN
  • Views 15096
netbug
netbug over 9 years ago
Dear all,
I have a csv file with the test names and corner setup.
format: test_name, Variable(s), corner
example of the content
AC Noise tt,passnom, 2.5V, etc ...
Tran ...
DC ...
then the  full csv is imported into a list.
Then, I would like to launch a Monte Carlo simulation per each entry in the list,  for a specific test and corner not touching anything in the test (saved nodes, expressions, variables, etc)
Thanks in advance.
Best regards,
Pedro
    One approach would be to use ADE XL (or ADE Assembler) to do this. The corners UI already has an export and import CSV mechanism - it's not quite in the format you describe (particularly how tests are referenced), but I'm sure with a bit of munging you can get the CSV into the right format to import.
    Then you could run from ADE XL, or export an OCEAN XL script to do this - or using ADE Assembler in IC617, you could do a simple maeLoadSetup(lib cell view) and maeRun() script to batch run it.
