  3. *Error* *INTERNAL*: helper function missing for - syntax...
  • Subscribers 150
  • Views 2051
*Error* *INTERNAL*: helper function missing for - syntax:or
archive over 18 years ago
I'm trying to work my way through this famous paper about Functional Programming. Naturally, I'm trying to use my favorite language, SKILL!
Unfortunately, I've run into something curious when I try to run this code in SKILL++ mode:
; Here's a function to sum a list. (define (sum list) (if (null list) 0 (plus (car list) (sum (cdr list))))) ; Note the "0" and "plus" are the only parts unique to (sum). ; We can modularise sum by glueing together a general recursive pattern: (define (reduce f x list) (if (null list) x (f (car list) (reduce f x (cdr list))))) ; Now we can redefine sum: (define (sum list) (reduce plus 0 list)) ; We can also reap benefits by re-using reduce to write other functions: (define (product list) (reduce times 1 list)) (define (anytrue list) (reduce or nil list))
All this code works fine, until I get to anytrue():
(anytrue '(nil nil t)) *Error* *INTERNAL*: helper function missing for - syntax:or
Yet this works if I re-write reduce() to use funcall():
(define (reduce f x list) (if (null list) x (funcall f (car list) (reduce f x (cdr list))))) (anytrue '(nil nil t)) t (anytrue '(nil nil nil)) nil
What's going on here?
Originally posted in cdnusers.org by tweeks
    Looks like a fairly obscure bug in the SKILL Virtual Machine. I filed CCR 569072 to get this fixed. Whilst syntax forms (e.g. or, and) are a little different (they don't evaluate their arguments before calling - they selectively evaluate depending on the value of each argument in turn), I don't see any reason why this should fail in this case.
    I suspect it may be something to do with the fact that the compiler cannot correctly produce the VM code that it normally would for a call to "or" because it can't see that the (f) call is actually a syntax form. But I'll leave it to R&D to check that.
    Originally posted in cdnusers.org by adbeckett
    I was right. It seems that handling of syntax forms needs something special, which hasn't been implemented for or/and. In practice these are the only two syntax forms which are likely to be used in this scenario, so the plan is to add the missing "helper functions" in the next release.
    Thanks Andrew! (BTW, is there any way for me to view that CCR? I only seem to be able to see my own...)
    I wonder if my continued voyages into the wonders of Functional Programming will reveal any other as-yet unexplored corners of the SKILL language?
    Speaking of Functional Programming, it's too bad SKILL++ doesn't have tail recursion--that would really make it a lot more Scheme-like. I don't suppose there are any plans to add that in.
    --tom
    You'd need to contact customer support and ask for a duplicate CCR to be filed - that way you can see the status from sourcelink.
    Tail recursion optimisation is requested, but not committed. You need to watch out when using recursion as an alternative to loops in SKILL because the stack for the call frame is not that large... (and because there's no tail call optimisation, you can't reduce it that way).
