  3. How to extract Pcell proprieties from a CV
  • Replies 8
  • Views 20809
VadimBorisov
VadimBorisov over 9 years ago
Hi all,
I need a small help, I want to extract of already existing pcell in the CV and them save it to the table. F.i. I need Width, number of gates and etc...
The question is how to find the data, where should I look?
Kind regards,
Vadim
  • VadimBorisov
    @moderator please move to Custom IC SKILL Forums, sorry for posting it here.
    It's not that clear quite what you want. You can find the parameter values on the instance, or in the instHeader information; depends on whether you just need to collect the data for all the variants in the design, or all the specific instances.
    Here's some code I wrote a while back to report the PCell variants in the design hierarchy; this was done to provide similar information to that produced by the Stream Out interface in IC5141 (the IC61X stream interface doesn't produce this). The code is in LISP syntax (that's my preference) - hope that doesn't put you off.
    /* abReportPcellVariantsUsed.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 14, 2012
    Modified
    By
    Code to report all the variants of pcells used in the design.
    Similar data came out of the "dump pcell info" option in pipo
    in IC5141, but that functionality is not there in xstream in IC61.
    To use:
    ; report on the hierarchy from the cellView in the current window
    abReportPcellVariantsUsed(?file "./report.txt")
    ; as above, but only showing non-default pcell parameters
    abReportPcellVariantsUsed(?file "./report.txt" ?nonDefault t)
    ; give a specific cellView id rather than current edit cellView
    abReportPcellVariantsUsed(?file "./report.txt" ?cv cvId)
    SCCS Info: @(#) abReportPcellVariantsUsed.il 06/14/12.11:59:31 1.1
    *           (abCollectPcellVariantsUsed cv [mastersDone pcells])            *
    * Traverse hierarchy recursively, returning a table containing the variants *
    *      for each pcell superMaster that are used in the design. The 2nd      *
    *      and 3rd arguments are only passed from within the function when      *
    *                         it is called recursively                          *
    (defun abCollectPcellVariantsUsed (cv @optional
                                          (mastersDone (makeTable 'done nil))
                                          (pcells (makeTable 'pcells nil)))
      (let (variants variantTable)
        ; Record that this master has been visited, to speed things up so
        ; that masters are not traversed more than once
        (setarray mastersDone cv t)
        (foreach instHeader (dbGetq cv instHeaders)
                 (if (setq variants (dbGetq instHeader variants))
                   ; If there are variants of this instHeader, record them
                   (progn
                     ; Either get the existing variant table for this
                     ; pcell superMaster, or create a new one
                     (setq variantTable
                           (or
                             (arrayref pcells (dbGetq instHeader master))
                             (setarray pcells (dbGetq instHeader master)
                                       (makeTable 'variants nil))))
                     ; Record any variants found in the table
                     (foreach variant variants
                              (setarray variantTable (dbGetq variant master) t)
                   ; Otherwise traverse the hierarchy if not already visited.
                   ; Note: This includes any pcell variants, which may contain
                   ; hierarchy
                   (unless (arrayref mastersDone (dbGetq instHeader master))
                     (abCollectPcellVariantsUsed (dbGetq instHeader master)
                                                 mastersDone pcells)
        pcells
    *  (abReportPcellVariantsUsed [?file poport] [?cv (geGetEditCellView)]  *
    *                          [?nonDefault nil])                           *
    * Writes out a report of all the variants used in the design hierarchy. *
    * The ?file can be either a fileName, or an open port. The ?nonDefault  *
    * argument allows you to restrict the report to only output non-default *
    *                 pcell parameters in the variants list                 *
    (defun abReportPcellVariantsUsed (@key (file poport) (cv (geGetEditCellView)) nonDefault)
      (let (pcells port defaults)
        (setq port
              (cond
                ((stringp file) (outfile file))
                ((and (openportp file) (outportp file)) file)
                (nil)))
        (when (null port)
          (error "abReportPcellVariantsUsed: first argument must be a valid file name to write to, or an open port: %L" file)
        (setq pcells (abCollectPcellVariantsUsed cv))
        (foreach master pcells
                 ; If asked to output just the non-default parameters only,
                 ; record the superMaster defaults in a table
                 (when nonDefault
                   ; since parameters can't be symbols, make default a spurious
                   ; value in case unlikely situation where variant has additional
                   ; parameter that the master does not
                   (setq defaults (makeTable 'defaults 'special))
                   (foreach param (dbGetq (dbGetq master parameters) value)
                            (setarray defaults (dbGetq param name) (dbGetq param value))
                 (fprintf port "PCell %s %s %s has variants:\n"
                          (dbGetq master libName)
                          (dbGetq master cellName)
                          (dbGetq master viewName)
                 (foreach variantMaster
                          (arrayref pcells master)
                          (fprintf port " ")
                          (foreach param (dbGetq (dbGetq variantMaster parameters) value)
                                   ; Output either just the non-default, or all parameters
                                   (when (or (null nonDefault)
                                             (nequal (arrayref defaults (dbGetq param name))
                                                     (dbGetq param value)))
                                     (fprintf port " %s=%L"
                          (fprintf port "\n")
                 (fprintf port "\n")
        (when (stringp file)
          (close port))
        t
    Kind Regards,
  • VadimBorisov
    thank you Andrew for the answer and for your work here!
  • VadimBorisov
    just one question: if I want to get data from all existing pcells not only from Master (repetition is ok), I mean, now it's only unique pcell variations, but for me the using frequency is also important.
    what should I change or where to look?
    In that case you'd need to visit all the instances rather than the instHeaders. You would need to look at each instance's master and then check to see if it has a superMaster (then you know it's a PCell), and the get the parameters from that (you'd need to look at the code above for inspiration as to how to figure out all the parameter values and output them).
    Unfortunately I can't write the code for you (I've given you quite a few examples already).
    Kind Regards,
  • VadimBorisov
    it would be necessary, thank you for the hint.
  • VadimBorisov
    sorry one more question, I am checking the properties of each transistor properties
    cv~>instances~>prop~>name
    but it only shows the parameters which have been changed compare to the default parameters. Is it correct? is there a way to get all parameters even if they are default?
  • VadimBorisov
    [update]
    the solution is to use the cdfGetInstCDF(instance_db) function.
