  3. Need an advise: which is the most continent way to save...
  • Views 16023
Need an advise: which is the most continent way to save dumped data to a table?
VadimBorisov
VadimBorisov over 9 years ago
Hi all,
I want to save the dumped data from PCell to a file (table), and there are many ways, which one you would suggest? Just create a table or maybe more advance f.i. JSON?
As an exmaple of my data:
cv~>master~>superMaster~>...
( "50n" "FALSE" "1u" .....)
Kind regards,
Vadim
    Vadim,
    I'm not sure anyone here can answer that. Doesn't this rather depend on what you want to do with the file you're generating?
  • VadimBorisov
    thank you for your answer.
    ok if I rephrase my question: How to extract data from Cadence and convert into JSON format?
    There are no specific APIs to aid outputting in JSON format; however, it's quite a simple text format so writing your code to dump out the data in JSON format using formatted print statements (e.g. fprintf) would be easy enough.
