  3. schematic creation using SKILL
  • Views 23944
sadgun
sadgun over 9 years ago
Can anyone help me in writing a SKILL code for creating a schematic of a basic circuit??
I have the netlist of the required circuit.
Based on the suggestions you give for creating a basic circuit, I can write for my schematic.
  • skillUser
    skillUser over 9 years ago
    What format do you have the netlist in?  Sounds like you want to use something like SpiceIn or VerilogIn to create a schematic from the netlist - don't re-invent the wheel!  I wouldn't recommend writing something like this from scratch in SKILL yourself unless somehow the other methods cannot work for you.
    Provide some more details if you need further guidance.
    Best regards,
    Lawrence.
  • sadgun
    Hi Lawrence,
    Thanks for your reply.
    The netlist is in spectre.
    Help me with some commands to create schematic.
    It's part of my project.
    Teja sadgun
    File->Import->SPICE can also read spectre netlists.
    If you really must do it in SKILL, you'd want to use either the db functions (dbCreateInst, dbCreateNet/dbCreateTerm/dbCreatePin) or more simply use the sch functions schCreateInst/schCreatePin/schCreateWire. I have tended to use schCreateWire/schCreatePin but still use dbCreateInst (schCreateInst doesn't add much value). If it's a transistor level circuit, you'll also have to set the properties on the devices themselves using either dbCreateParamInst or similar, or using dbReplaceProp or instId~>w="2u" etc, and may then want to call the CDF callbacks (search in these forums for abInvokeCdfCallbacks or on support.cadence.com for CCSinvokeCdfCallbacks).
    Here's some code which generates a big schematic that I used for testing something. Might give you a clue, although I didn't add many comments, and it's in Lisp syntax, which you may not be familiar with:
    /* abCreateBigSchematic.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 25, 2014
    Modified
    By
    Silly example to create a big schematic in order to exercise the
    performance of some of the tools.
    Note that this makes a number of wild assumptions - for example, that there
    will be only 2 pins on each cell being arrayed.
    SCCS Info: @(#) abCreateBigSchematic.il 07/25/14.12:45:52 1.1
    (defun abCreateBigSchematic (@key (cv (geGetEditCellView)) (numInsts 1000) (numParallel 10)
                                    (lib "analogLib") (cell "res") (view "symbol")
                                    (stepX 0.5) (stepY 1.0) (stubLength 0.125) (textHeight 0.0625)
                                    verbose)
      (let (master (x 0) (y 0) pinLocations pinMaster netName1 netName2 wire numRows)
        (setq master (dbOpenCellViewByType lib cell view))
        (setq pinMaster (dbOpenCellViewByType "basic" "iopin" "symbol"))
        (setq pinLocations
              (foreach mapcar terminal (dbGetq master terminals)
                       (centerBox (dbGetq (dbGetq (car (dbGetq terminal pins)) fig) bBox))
        (schCreatePin cv pinMaster "PLUS" "inputOutput" nil (list x y) "R0")
        (setq netName1 "PLUS")
        (setq y (plus y stepY))
        (setq numRows (quotient numInsts numParallel))
        (for row 1 numRows
             (when (and verbose (zerop (mod row 100))) (printf "Row %d\n" row))
             (if (equal row numRows)
               (setq netName2 "MINUS") (sprintf netName2 "net_%d" row))
             (setq x 0)
             (for col 1 numParallel
                  (dbCreateInst cv master "" (list x y) "R0")
                  (foreach (pinLoc netName) pinLocations (list netName1 netName2)
                                 (setq pinLoc (dbTransformPoint pinLoc (list (list x y) "R0" 1)))
                                 (setq wire (schCreateWire cv "route" "full"
                                                           (list pinLoc (list (plus (xCoord pinLoc) stubLength) (yCoord pinLoc)))
                                                           0.0625 0.0625 0))
                                 (schCreateWireLabel cv (car wire) pinLoc netName "lowerLeft" "R0" "stick" textHeight nil)
                  (setq x (plus x stepX))
             (setq netName1 netName2)
        (schCreatePin cv pinMaster "MINUS" "inputOutput" nil (list x y) "R0")
        (schCheck cv)
        (dbSave cv)
        t
