  3. Regular Expressions
  • Subscribers 148
  • Views 11974
Regular Expressions
Serjik
Serjik over 9 years ago
Hi all,
Can anyone help to solve the problem ?
I've got a library (shem) with lots of cells. Each cell contain schematic view and a symbol. If the name of the cell begins with "dff" or "lat" i need to run df procedure, if it doesn't, i have to run pn procedure. But i stuck with regular expressions for that.
Here is the code:
l=ddGetObj( "shem")~>cells
v = listToVector( l)
for( i 0 (length( l)-1) ddGetObjName( v[i])
    case(ddGetObjName( v[i])
        (rexMatchp("^dff*")
        df( ddGetObjName( v[i])))
        (rexMatchp("^lat*")
        (t
        pn( ddGetObjName( v[i])))
);case
);for
df and pn procedures use cellName as a parametre.
Maybe there is anothe wey to get cellNames from the library ?
containce
containce
containce
containce
containce
  • ebecheto
    ebecheto over 9 years ago
    Is that whyat you are looking for ?
    _______________
    ;; copyleft ebecheto
    ;pattern=".*_sim"
    ;pattern;=> ".*_sim"
    ;(setq libNames ddGetLibList()~>name)
    ;(setq libNames '("analogLib"))
    defun(rexFindCell (@optional (pattern ".*_sim") (libNames ddGetLibList()~>name))
    " commentary "
    let( (ddLibs)
    unless(listp(libNames) libNames=list(libNames))
    ddLibs=setof(dd ddGetLibList() member(dd~>name libNames))
    assocLib=foreach(mapcan dd ddLibs foreach(mapcan cc dd~>cells list(list(dd~>name cc~>name))))
    ; lib_cell=nth(3 assocLib);=> ("analogLib" "xfmr")
    remove(nil foreach(mapcar lib_cell assocLib
    if(rexMatchp(pattern cadr(lib_cell)) then lib_cell else nil)
    ;; _USAGE_
    ;; rexFindCell(".*_sim")
    ;; rexFindCell("^mos" '("PRIMLIB" "analogLib"))
    ;; rexFindCell("cap$"  "analogLib")
    ;; rexFindCell("^simu_" )
    printf("rexFindCell(\"^mos\" '(\"PRIMLIB\" \"analogLib\"));<== search in lib for cells starting by nmos\n")
    printf("rexFindCell(\"^simu\"));<== search cells starting with simu in all libraries\n")
    printf("rexFindCell(\"cap$\"  \"analogLib\");<== searching in one lib for cell ending with name cap\n")
  • ebecheto
    sorry i read your question too fast. Your bug is : PUT A DOT BEFFORE STAR
    ^dff.*
    ^lat.*
  • skillUser
    skillUser over 9 years ago
    Hi Serjik,
    You can iterate directly over lists in SKILL using foreach, it is very powerful and convenient, here's an example:
    let( (namePat)
      namePat = pcreCompile("^(dff|lat)") ;; name begins with either 'dff' or 'lat'
      foreach(cell ddGetObj("shem")~>cells
        when(pcreExecute(namePat cell~>name)
          ;; do your processing here
        ): when
      ); foreach
    ); let
    Hopefully this is what you are looking for?
    Best regards,
    Lawrence.
  • Serjik
    Thanks to everybody.
    Now it great.
