  3. what is the difference between 'rex' and 'pcre' SKILL regex...
  • Views 2226
what is the difference between 'rex' and 'pcre' SKILL regex functions ?
Manikk0501
Manikk0501 over 9 years ago
Hello experts,
I have a basic doubt regarding regex functions in SKILL. There are two set of functions which has suffix 'rex' & 'pcre'. I understand pcre stands for perl compatible regular expression. If someone explain it providing a small example, it will be very useful to understand it.
Thanks and Regards,
Manikandan Kuzandhaivelu
  • skillUser
    skillUser over 9 years ago
    Hi Manikandan,
    Did you do *any* research before posting, like looking in the SKILL documentation for example?
    The documentation notes the following (in Pattern Matching Functions) for the "rex" functions (e.g. rexMatchp, rexMatchList ...):
    c  Any ordinary character (not a special character listed below) matches itself.
    .  A dot matches any single character
    \  A backslash when followed by a special character matches that character literally. When followed by one of <, >, (, ), and 1,…,9, it has a special meaning as described below.
    […]  A nonempty string of characters enclosed in square brackets (called a set) matches one of the characters in the set. If the first character in the set is ^, it matches a character not in the set. A shorthand S-E is used to specify a set of characters S up to E, inclusive. The special characters ] and - have no special meaning if they appear as the first character in a set.
    *  A regular expression in the above form, followed by the closure character * matches zero or more occurrences of that form.
    There's more, but not much in comparison to the full regular expression capabilities of the pcre* functions. Hopefully the above gives you some idea of the difference, but maybe also where to look to get a fuller picture.
    Best regards,
    Lawrence.
