  3. How to call an instance into layout
  • Views 19327
Muralidhar
Muralidhar over 9 years ago
I am writing a program to call the devices from the technology library (P cells) using the following code
master=dbOpenCellViewByType("cmos28g" "nfet" "layout")    ;cmos28g is the library, nfet is the cell name and layout is view name
paralist=list(list("W" "float" "0.5") list("L" "float" "0.5"))
dbCreateParamInst= (geGetEditCellView() master "instname"  list(0 0) "R0" 1 paralist)
By excuting this program I am getting the instance in my layout but not with the parameters that I specified. It is coming with the same parameters that are in the original layout (i.e., in the cmos28g library layout).
Is there anything wrong in the program ?  (or) Do I need to include anything else?.  Please clarify it.
Thanks.
  • skillUser
    skillUser over 9 years ago
    I don't think that this can be your code, for example, I see the following typo:
    The instance name would have to change for each instance also.
    If this is your code then I would not have expected it to work, but anyway, fix the typo above and/or post your real code.
    Good luck!
    Lawrence.
  • Muralidhar
    Actually, that was my typo mistake. Following is the actual code
    gen_inst=dbCreateParamInst (geGetEditCellView() master "instname" list(0 0) "R0" 1 paralist) ;anyway instname will be varied
    I tried this code to generate a single device.
  • skillUser
    Then you must have the parameter names incorrect. Take a look at Tools -> CDF -> Edit for the nfet cell from the cmos28g library - I'm guessing the parameters are actually named something like "w" and "l" (lowercase) - but check for sure in the CDF. The instance you have created probably has properties for "W" and "L" rather than parameters for "w" and "l", hence you get a default device.
    Try again and report back.
    Lawrence.
  • Muralidhar
    The CDF parameters are defined with lowercase letters only (l, w). But when I use the lowercase letters in paralist like
    paralist=list(list("w" "float" 0.5) list("l" "float" 0.5))
    I am getting a warning in my virtuoso as dbCreateParaminst : Datatype for input parameter 'l' does not match with the definition
    and getting the result as nil.
    If I use uppercase letters atleast I am getting device.
  • skillUser
    Well you have to match the expected type of the parameter also! It is probably a string, not a float, which is why you are getting the warning. Look again, closely, at the CDF parameters when you do Tools -> CDF -> Edit, you will see the parameter type, make sure you provide the type and value to match what is expected.
    Best regards,
    Lawrence.
  • Muralidhar
    I changed it. Now, it is working thanks for your suggestions
