  3. Substituting variables in the dpl arrow operators?
  • Views 16381
Ienstein
Ienstein over 9 years ago
This is what I would like to do:
dpl1 = list(nil 'var list( 1 2 3))
x = 'var
dpl1->x  =>  ( 1 2 3) ; desired result
I can't get the arrow operator to properly reference 'var from x instead of literally x
Any thoughts much appreciated!
    The -> operator (for retrieval) corresponds to the getq() function, which means that the argument is implicitly quoted. So the property name is not evaluated if you do it this way - it would try to retrieve a property called "x".
    Instead use get(dpl1 x) which does exactly what you want.
  • Ienstein
    Awesome! Thanks Andrew. I tried all kinds of weird contortions trying to get this to work :)
