  3. How to release the memory in script, for "User defined skill...
  • Views 2798
How to release the memory in script, for "User defined skill function" in the calculator
fatcat1206
fatcat1206 over 9 years ago
Hi All
As requested by my colleague, I wrote a skill script to define a "User defined skill function" for the calculator.
This function works like a "moving DFT".
It defines a time window that goes through the signal waveform, and doing the DFT for the part of signal which has been clipped by this time window. And then the ymax() of the DFT results has been stored
As you can see, there are might be quite some DFT has been executed while the time window going through whole simulation time.
The script works fine, the big issue is that the memory has been run out in short time. (after doing the calculation for the 4 times, according to my colleague).
I'd like to know if there is a method to release the memory in command line.
Then I can release the memory every time when the DFT has been executed and ymax() has been stored.
Best Regards
Yi
  • skillUser
    skillUser over 9 years ago
    Hi Yi,
    Make sure that your SKILL code gets a good SKILL Lint score, especially regarding global variables (Tools -> SKILL IDE). You could try forcefully calling "gc()" in your code to perform garbage collection? If these suggestions do not help you could either post your code here to see if someone can help or file a Case with Cadence.
    Best regards,
    Lawrence.
    Hi Yi,
    I agree with Lawrence - it may be the way the code is written - or it may just be because there was nothing to trigger the garbage collection. Even with garbage collection the memory probably won't get restored to the OS (as is common with most UNIX programs unless they have relatively simple memory management).
    Either way, the best way of investigating this is to file a case with customer support (you can always put me on copy and then I'll pick it up).
  • fatcat1206
    Hi Lawrence
    Thanks for the hint of "Lint", I use it every time for my new scripts, it helps a lot.
    I just check my script once again, it has Lint score of 94, due to I accidentally removed one local variable definition.
    After correct this, the Lint score is 97, due a global variable for the "form" (that's the thing always prevent me for score 100)
    I have filed a case, and submit my script there. Case number is #46106273
    Best Regards
    Yi
  • fatcat1206
    Hi Andrew
    Thank you for your suggestions. And sorry for the late reply that I just come back from my 3 weeks holidays.
    I have filed a case, and submit my script there. Case number is #46106273.
    Hopefully you or Lawrence have time to take a look at my script, and give me some suggestions to improve it.
    Best Regards
    Yi
    Hi Yi,
    I've picked it up and will look at it later today. Lawrence wouldn't have been able to since he hasn't worked for Cadence for over 2 years!
  • fatcat1206
    Hi Andrew
    Many thanks in advance.
    Best Regards
    Yi
