  3. dbWriteSkill encounter : error close:error closing file
  • Views 2058
rockyicer
rockyicer over 9 years ago
hi,
  i am using the code:
cvId=dbOpenCellViewByType("test" "otcind" "layout" "maskLayout")
dbWriteSkill(cvId "/home/s01/a.il" "w" "4.4")
to dump a graphical pcell skill code in IC616,
when i run the first skill sentence: cvId=dbOpenCellViewByType("test" "otcind" "layout" "maskLayout")
the feedback is OK.  but when i run the second one: dbWriteSkill(cvId "/home/s01/a.il" "w" "4.4")
 the CIW feedback the following error:
*Error* close: Error closing file
I have check the path:/home/s01/a.il and its disk space is not full.  This post (support.cadence.com/.../ArticleAttachmentPortal;pageName=ArticleContent&sq=005d0000005nekwAAA_201722416744619) says it has relation to the /tmp file. (I don't have access to the /tmp file.) Is it ture? and how can I solve this problem?
thanks in advance!
    That article is about the stream interface, and not dbWriteSkill - so it's not really relevant when talking about /tmp. I don't believe dbWriteSkill writes anywhere other than the path you specify - it writes two files if it's a pcell - the cellView dump, plus the pcell code. Both are in the same directory.
    I've found no reports of this. It might be that the disk isn't full, but maybe your quota is exceeded and so you can't write any more data? Errors during closing of files are pretty rare... the most likely situation is that when trying to flush the buffer and actually write to disk it can't because it's not allowed to write any more to the disk. Generally commands such as "quota -v" would tell you your quota situation - but it's probably best to check with your IT in case the quotas have been set up differently (if that's what it is).
