  3. Using SKILL to auto-update VerilogA & Symbol views
  • Views 2815
AzarK
AzarK over 9 years ago
I am trying to use SKILL to take a Verilog-A text file and:
  1. Check and save, generating additional Cadence files and updating CDF parameters
  2. Regenerate symbol from updated view list
After scouring the forums and the web, I found the vmsUpdateCellViews( <lib> <cell> <view> ), which will achieve (1), sort of. If I use this command on a single file, this works well, since I will often get UI prompts to update the CDF and/or symbol. Unfortunately, if I try to do this on multiple files, the function doesn't wait for the UI prompts to be closed before moving to the next line in the SKILL script. The UI interfaces then become unresponsive as the script to continues to execute.
I have also tried to use schViewToView() function, but I can't find a built in "fromFunction" for Verilog-A (schVerilogToPinList() does not seem to work for Verilog-A). The schHiViewToView sort of works, but requires a lot of manual inputs. Is there a simple way to do this for a standard Verilog-A text file?
Azar
  • AzarK
    I realized after reading an unrelated post that putting UI calls inside of a let( ) block functions differently than just putting lines in a .il file and loading. If I nest the vmsUpdateCellViews() calls inside a let() block, then each call waits for resolution of any prompts before moving to the rest of the script. This solution is good enough. Thanks,
    This solution on the support site also gives some info about how to turn off the popups altogether.
  • AzarK
    Thanks Andrew. The linked article was very helpful, and I have everything I need now.
    Azar
