  3. Align pins based on connectivity
  • Views 16638
RK56
RK56 over 9 years ago
I'm looking for a function which can align pins to objects with similar net name. For example say I have an instance and pins only in layout. Now I want to place pins directly over the instance's pins.  In Edit->Advanced->Align there is an option to do this but I get the following error.
*WARNING* (LX-3009): Cannot run pin alignment because there are no pin pairs to be aligned.
Can somebody help me? I'm using virtuoso version ICADV12.2-64b 04/13/2016 08:41
-Ramakrishnan
  • Quek
    Quek over 9 years ago
    Hi Ramakrishnan
    You can do it as follows using the "Pin Placer" function:
    a. Switch to layoutXL using "Launch->Layout XL"
    b. Ensure that there are flight lines linking the top level pins to the pins of the instance
    c. Go to "Place->Pin Placement"
    d. Use "Level-1 pin" as the edge attribute
    Please search for "Placing a Pin on a Lower-level Instance Terminal" in $CDSHOME/doc/fphelp/fphelp.pdf.
    Best regards
    Quek
  • RK56
    Thanks Quek. I will try your option
