  3. multi-technology simulation netlisting through command line...
  • Views 16155
Muddler Wang
Muddler Wang over 9 years ago
Hi, All, I am doing top level mixed-signal multi-technology simulation (MTS).  To generate a mutli-technology analog netlist, I need to start ADE XL GUI, config it into MTS mode, and generate netlist through GUI. Wondering whether there is a way to generate the MTS netlist through command line?  Like:
bsub -I virtuoso -nograph +(arguments to invoke ADE XL and generate the netlist)
Thanks a lot for helping!
    Not as far as I know. Normally the MTS netlists are only produced when you actually simulate. To have some means to batch create the netlists would probably require an enhancement request.
  • Muddler Wang
    Got it. Thanks Andrew. Hopefully this function can be built in the future updates.
    It's unlikely it would be unless you actually request it (this is not the place to make enhancement requests; you need to do that via support.cadence.com)
  • Muddler Wang
    I see, I will make a request there. Thanks a lot Andrew!
