  3. when is .cdsinit.local loaded?
  • Views 25891
SteveRFIC
SteveRFIC over 9 years ago
I have a questions on .cdsinit.local file
I did some customization (bindkeys etc.) in .cdsinit.local file and I put the file in my cadence working directory.
When I start cadence, when is .cdsinit.local loaded?
What I found is that some of the customization gets overwritten by scripts loaded later from the project/company environment. As a results, I have to load again my bindkeys after cadence fully starts.
Is there a way to put .cdsinit.local at the end of the list of files loaded when cadence starts, so that it won't get overwritten?
Or is there a way to use the pop up window (like the what's new window)  to trigger the loading of some skill code?
Thanks!
    There is nothing in virtuoso that loads a file called ".cdsinit.local". All that happens is that virtuoso looks for a file called ".cdsinit" (in various places; the order of which can be overridden with the Cadence Search File mechanism, if you desire) and then loads the first one it finds.
    Often CAD groups customise the .cdsinit so that it loads other files; in your case it appears that it looks for and loads a file called ".cdsinit.local". The order in which it does that is completely determined by however that CAD team has written the SKILL code in their .cdsinit. I cannot answer this generally, because it depends on the specifics of that implementation.
    You should contact your own CAD team to find out how they've done it and what controls they provide (if any) for changing the order of when this customer-specific file gets loaded.
  • SteveRFIC
    Thanks Andew!
    Indeed this is customized settings from the CAD team, where loading .cdsinit.local file is defined in .cdsinit
    It seems that .cdsinit is the only place to define any customized settings, is this correct? Does cadence also try to load some other files?
    I remember that Cadence searches a few paths for .cdsinit file before starts, does it load the first one it finds? what if I have two .cdsinit file located at different locations, and they differ in content, will both .cdsinit file be loaded?
    There are two SKILL files that get loaded - .cdsinit and .simrc. However, ,simrc is only loaded when netlisting is performed, and customisations in their should be limited to just those related to netlisting (it's also loaded multiple times per session).
    There's another file, libInit.il, which lives in a library and is loaded the first time that a library is accessed. That's normally intended for library-specific actions.
    So in general I'd say you should sort out with your CAD team a way of loading customisation in the order you need.
    In general, the rules for loading the .cdsinit are:
    1. If there is no csfLookupConfig file which has an 'INCLUDE .cdsinit' line in it, the search order is:
      1. <ICinstDir>/tools/dfII/local/.cdsinit
      2. ./.cdsinit
      3. ~/.cdsinit
    2. If csfLookupConfig has been defined, it searches using the "setup.loc" order. You can check this with:
      cdswhich -lookupconfig .cdsinit
      This will tell you if .cdsinit has been configured to be found via CSF (cdswhich csfLookupConfig will check the file and you can look at the contents) and if so, which path was found. The order can be found by looking at the contents of whatever "cdswhich setup.loc" returns.
    In both situations, whichever file is found first in the search sequence is the only one loaded (by virtuoso). It does not load any later files in the sequence (unless that has been coded into the first .cdsinit file it loads).
  • SteveRFIC
    All clear now. I'll sort it out with the CAD team.
    Thanks Andrew!
